Do you have a screw on cap to close the inlet to your fresh water holding tank off, if so put it on and use the water pump and see if your getting water to all outlets in the Trailer, some pumps will not pump/ run until you cap or close these inlets off outside, the only shut off valve to your holding is the water supply from outside on the pedistal, if the fresh w/tank is full let it overflow until it stop by itself. If and when it stop close it off with the inlet cap then hookup to your city water supply for normal use, try not to exceed 45 psi water pressure and use a water filter as much as possible....Good Luck
