Originally Posted by jdkbrooks
I have a shower drain issue and opened access under the shower and there is no p trap I'm guessing it is someplace else but haven't found it yet
Had you read
Post #14 in this thread before posting, you would have seen that you probably have a HepVo valve, not a P-trap. These one-way valves (see the image) are used where there is not sufficient height for a P-trap, a common situation in RV showers. From the outside they look like a simple pipe coupling.
Don't go jamming a snake through a HepVo. You will destroy the tube within it, and be plagued by odors from the gray tank. You could try a plunger in the shower, or even a Drain King.
