Old 07-21-2020, 10:27 PM   #1
Sink Bubbling while in shower
I've got a 2019 Rockwood ultralite 2706. Just noticed tonight my bathroom sink is blowing water out of the drain every once in a while I'm in the shower. Grey tank is getting full according to the panel. Wondering what it is. It's stinks like rotten eggs and makes a mess.
Caylin2020 is offline   Reply With Quote
Old 07-22-2020, 04:44 AM   #2
Chris Pastuzyn's Avatar
Welcome from New Jersey, most likely that tank is full ,Try emptying it b4 the next you shower and see what happens.
Chris Pastuzyn is offline   Reply With Quote
Old 07-22-2020, 04:48 AM   #3
fonzie's Avatar
The tank vent might be plugged.
Fonzie
Old 07-22-2020, 04:59 AM   #4
Probably the tank vent.
Michael & Fran Dilday (Baxter & Honey 2 Labs)
'18 Cedar Creek Champagne 38EL - '17 Ford F350 Lariat DRW w/Reese hitch - TST 507 Color TPMS - Garmin RV 770 LMT GPS
mwdilday is offline   Reply With Quote
Old 07-22-2020, 05:43 AM   #5
nomad297's Avatar
It may Just (hopefully) be the tank vent clogged with a wasp nest or something else, but it could also be (hopefully not) that the drain and/or the vent (which could be one and the same if your shower is wet vented through the sink drain and the sink vent is also serving as your tank’s vent) entering the tank is pushed too far into the tank. If this is the case, when the water in the tank gets up to the level where the bottom of the pipe is, the vent is no longer venting to atmosphere. What you have described would have nothing to do with an air admittance valve (AAV), so don’t waste your time and money replacing that. Your issue is an atmospheric venting problem.
Bruce
nomad297 is online now   Reply With Quote
Old 07-22-2020, 07:01 AM   #6
Flybob's Avatar
The tank vent sticks down into the tank from the top. It should only extend a little way down as once it gets below the line of the liquid, it does not work well. The vent pipes have been known to slip down over time and travel and cause what you are seeing. You can check this by going on the roof and removing the vent cover and checking the vent pipe (PVC). A quick field fix is to dump the tank as sooner.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 07-22-2020, 07:50 AM   #7
nomad297's Avatar
But not all gray tanks have a dedicated vent and use the vent off of the kitchen sink or lavatory instead.
Bruce
Old 07-22-2020, 01:21 PM   #8
Palinduff's Avatar
My first thought.
2017 F150 Eco Boost, SC, 8' Box, 4X4
Max Tow (10 speed, 3:73, 11,700lbs), HD Payload (2440lbs)
2015 Puma 253 FBS
2013 Hyundai Santa Fe
2000 Honda EX 400
Palinduff is offline   Reply With Quote
Old 07-22-2020, 02:04 PM   #9
njfishing's Avatar
My bet is your great water tank is getting full...
Gerry Z
2018 Forest River Heritage Glen 272RL
2018 Ford F150 Lariat 3.5 Ecoboost Max Trailer Package
Curt Trutrack WDH
HD Roadmaster Active Suspension
njfishing is offline   Reply With Quote
Old 07-22-2020, 05:50 PM   #10
What everyone said plus, to help with the smell start using some Gray Tank treatment. Tablets or pouches that will help dissolve the soap scum that accumulates in the tank and eventually ferments, giving off a stench like a septic tank.
These treatments also contain a odor suppressant that gives off a citrus aroma as a rule.
Add one after emptying the tank, just like for a Black Tank.
I've used these with good effect. About $0.90 each and add to a drain after dumping the tank.
https://www.amazon.com/Walex-TOI-917..._t1_B0006H92QU
There are others that I'm sure work just as well.
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
Old 07-22-2020, 10:16 PM   #11
ARLO
Time to go dump the gray water.
rlocicero is offline   Reply With Quote
show, shower, sink
