Originally Posted by Macrosill
I found out why my gray tank is draining so slowly. The plug from when the factory drilled the tank for the drain is still in the tank and blocking the drain hole. See that picture below.
You are in luck. A 2018 will still be under warranty, take it to the dealer and let them deal with it!
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
