Old 06-25-2020, 08:37 PM   #1
slow filling fresh water tank
We have a Rockwood Minilite 2511s camper we bought last year and find the fwt fills slowly and have gurgling sounds at times from the fresh water tank tubing as water is added. Also had small amount of water come back through air vent line. Has else run into this issue and did you fix it yourself?
Del
2020 Rockwood Minilite 2511S
2012 F 150 Ecoboost
delseb is offline   Reply With Quote
Old 06-25-2020, 08:43 PM   #2
HONDAMAN174's Avatar
Is there a way for you to see where the tubing comes thru the wall and down to the tank? Maybe underneath the sink? If they cut the hose too long and has an upward angle it will cause these issues. Then it would just need to be trimmed
Just glad to get away
Old 06-25-2020, 09:05 PM   #3
That is normal.
You are putting a lot of water in, and the vent line is small.
2018 Flagstaff 832IKBS Travel Trailer.
2015 Silverado High Country.
jackhartjr is offline   Reply With Quote
Old 06-25-2020, 09:26 PM   #4
A32Deuce's Avatar
If you try to fill to fast, more water going in than air can get out. Start slow and slowly increase till you hit an even fill amount.
A32Deuce is offline   Reply With Quote
Old 06-26-2020, 10:17 AM   #5
Our tank is covered from below but may find air vent by looking here and there
Del
2012 F 150 Ecoboost
Old 06-26-2020, 10:33 AM   #6
There is nothing wrong with it. It fills slow because you are putting water in faster than the little vent can keep up.
Old 06-26-2020, 03:27 PM   #7
Tundra 2014
FWT
Just for point of comparison-it takes approx. 8 minutes to fill my 40 gallon tank. Even longer if low water pressure. As others have said, too much water w/o enough vent is probable cause. Mine spits thru vent if I try to fill too fast. Not to say that FR has not bent the vent hose on install, but sounds normal. You might be able to blow thru the vent to check for any restriction.
Tundra 2014 is offline   Reply With Quote
Old 06-26-2020, 05:40 PM   #8
When I had this problem on an SOB TT, the service center found the air vent was bent and kinked when the tank was pushed up into position at the factory. They dropped the tank a bit and relieved the kink; filled just fine after that.
Greg 'n Deb
2020 R-POD 195 HRE
'17 Tacoma 3.5L,'07 Tundra 5.7L w/ tow pkgs.
Dirt Sifter is offline   Reply With Quote
Old 06-26-2020, 05:46 PM   #9
I use one of these to fill my tank. Water is on full blast, no burps until it is full.
https://www.etrailer.com/RV-Fresh-Wa...01-0031VP.html
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
upflying is offline   Reply With Quote
Old 06-26-2020, 06:35 PM   #10
jeff64's Avatar
Take a piece of tubing like maybe the hose from a shower, place it on the vent by the filler opening and blow on it, if a slug of water is lying at the low point, you'll blow it out and you can fill your tank
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
Old 06-26-2020, 08:19 PM   #11
Its taken 25 minutes to fill 50 gallon tank. Stopping several times to allow air to escape the inlet hose. I use short piece of hose that goes approx. 8 inches into water line.
Del
2012 F 150 Ecoboost
Old 06-27-2020, 04:17 PM   #12
Just reading about your problem with the fresh water fill, I own a 2018 2509 by forest river and had the very same problem. This spring due to covid I decided to drop the under belly cover to examine the support for the fresh water tank as I sometimes travel with it full and may need more support.
Now while I was in there I found my tank fill problem, The actual fill pipe had a droop in it which would act like a trap in the line causing a restriction for gravity feed water flow.
Now someone in there wisdom at the factory decided to loop the vent pipe around that before being hooked to the vent causing a definite restriction once it got water in it with nowhere to go but spit and sputter if enough pressure built up. The fix was tie the fill line up so no water laid in the pipe and I unhooked the vent and tied it up so it also was unrestricted. I can now fill with an open hose with no back pressure buildup. Hope my experience helps. Great to have these forums to see others experiences and possible fixes.
Don't know where quality control fits into some of these problems that shouldn't be in the first place!
warsaw is offline   Reply With Quote
Old 06-27-2020, 06:21 PM   #13
Thanks for your advice. Not sure if I want to try and open the belly. Their is a long row of screws right under the tank. Is it easy to do?
Del
2012 F 150 Ecoboost
Old 06-27-2020, 06:29 PM   #14
Delseb, how long does it take to fill your tank?
I've had two Flagstaffs, both took awhile to fill. I just knew it and didn't worry about it!
Old 06-27-2020, 10:23 PM   #15
Tom48's Avatar
Better yet I use that and add one of these for precision. We have carried 100 gal or more in current and prior 2 rigs. And I fill at 3 or 4 gallons a minute.
https://www.amazon.com/Orbit-56854-H...49413728&psc=1
Tom48
In Sunny So Cal /w
Now in 2005 Holiday Rambler Ambassador DP and The Hot Air Balloon RESTLESS
NO MORE Tricked out
2017 Sandstorm 250 T.H.
Tom48 is offline   Reply With Quote
Old 06-28-2020, 07:12 AM   #16
It takes around 25 minutes to fill.
Old 06-28-2020, 07:32 AM   #17
That's a little slower than mine. I haven't timed it, I would say it about 15 for me.
fresh water, tank, water, water tank
