Old 07-17-2023, 01:52 PM   #1
Slow leak troubleshooting
Our 2022 Wolf Pup is our first camper/RV, and this is my first time troubleshooting a water or plumbing leak.
What I'm seeing:
  • Slow dripping from the underbelly but only noticeable so that it drips off the underbelly "railing"
  • Fresh water tank went empty for the first time during a trip.
How do I begin to troubleshoot this? The mesh layer protecting the underbelly seems difficult to get into.
I have reached out to the dealer but they are quite busy and haven't heard back. Obviously, will keep trying them but wanted to get some feedback from the community on this.
2022 Cherokee Wolf Pup
2022 Tundra SR5
brunoforestier is offline   Reply With Quote
Old 07-17-2023, 06:13 PM   #2
MillMitch's Avatar
Is your water pump cycling on and off? That should tell you if itís the lines or the tank. I would start with the easy stuff- make sure low point drain caps are tight, check under all sinks and shower for loose connections (or dampness). If the FW tank is leaking youíll need to pull the bottom down.
Mitch in MN
2018 Patriot (Grey Wolf) 23MK travel trailer
2011 Durango 5.7L and OEM tow package
MillMitch is offline   Reply With Quote
Old 07-19-2023, 10:37 AM   #3
Pump is not cycling on/off.
Nothing inside the camper is visibly wet.
What do you mean by "pulling the bottom down" on the FW tank?
2022 Tundra SR5
Old 07-19-2023, 11:08 AM   #4
NMWildcat's Avatar
The only way to get to the leak is to gain access to the plumbing so you can see what is going on. Some models you can get access from the top via access panels and cubbies. Others you need to remove the bottom 'mesh' covering.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
Old 07-19-2023, 01:19 PM   #5
Kanadian Kamper
kenandterry's Avatar
What I'm seeing:
Sorry, but youíre going to find your dealer is not much help after they got your money. You have to be very DIY with an RV.. LOTS of help here, just ask, but make sure to provide as much detail as possible. Pictures are always best.
Ken and Terry
kenandterry is offline   Reply With Quote
Old 07-19-2023, 03:50 PM   #6
After getting back in touch with the dealer this week, I agree. They are not very interested in helping. It's a 5-week wait to get an appointment.
Here's a photo. I don't think it's super informative but it does show what amount of water is leaking (not much) and where. I will note that the leaking has occurred in all areas of the side railing where the mesh meets it. It just depends on which side of the trailer is lower, given the slope of where it's parked.
2022 Tundra SR5
Old 07-19-2023, 03:52 PM   #7
here's the photo
2022 Tundra SR5
Old 07-19-2023, 03:53 PM   #8
Are there any guides on how to properly removing and re-attaching that mesh?
2022 Tundra SR5
Old 07-19-2023, 04:28 PM   #9
bikendan's Avatar
Maybe some YouTube videos.
Nothing from the manufacturer.
Sent from my SM-G781U using Forest River Forums mobile app
Old 07-21-2023, 04:57 PM   #10
MillMitch's Avatar
Are you positive your unit is sealed underneath? If so, it's usually coroplast (?), which is thin plastic. Crawl underneath and look for fasteners.
Mitch in MN
Old 07-21-2023, 05:32 PM   #11
The bottom material is likely coroplast and it can be attached by either self-tapping screws (if you are lucky) or nails that are fired into the frame. If screws, you can loosen and drop the covering. If nails, they will need to be pried with a nail puller or ground off with a grinder/Dremel tool.
Another option - if you have an idea of where to check - is cutting a 3-sided flap in the coroplast, folding it down and taking a peak inside. You can then re-seal the sides with zip tape, Eternabond, Gorilla tape of some other heavy duty product.
If the pump isn't cycling it's possible the FW tank may be the culprit. It is probably located in line with the FW fill port on the side of the trailer.
Are you able to keep the FW tank empty? If so, any leaking then?
2022 Rockwood Signature 8324SB
(kept permanently at our seasonal site)
markcee is offline   Reply With Quote
Old 07-23-2023, 10:13 PM   #12
I appreciate everyone's replies here.
I took the trailer to a RV repair shop (non-dealer) and turns out the FW tank was missing the tank vent hose.
Has anyone heard of such a mishap from a dealer-delivered brand-new trailer?
2022 Tundra SR5
Old 07-23-2023, 10:38 PM   #13
More than anyone wants to admit
2022 Chevy 3500 Diesel SWD
2022 Columbus 329 DVC
moose074 is offline   Reply With Quote
Old 07-24-2023, 07:59 AM   #14
Missing drain pipe under sink. Missing black tank vent pipe. Lots of stories like yours, from all kinds of brand-new RVs. It's the sad state of the industry.
stephndudb is offline   Reply With Quote
leak
