Old 12-07-2016, 11:40 AM   #1
Socket for Suburban Hot Water Heater
I'm winterizing. Does anyone know the socket size required for a Suburban hot water heater?
1000 Thanks!
Seakayaker
Charleston, SC
2016 Silverado 1500 LTZ
2016 Wildwood 27RKSS
seakayaker is offline   Reply With Quote
Old 12-07-2016, 11:43 AM   #2
danny4127's Avatar
1 1/16 " on mine
Danny and Beverly Plus Panhead (chiweenie)
2019 5th wheel
2016 DOGE RAM 2500
2013 HARLEY TRI-GLIDE
danny4127 is offline   Reply With Quote
Old 12-07-2016, 11:51 AM   #3
Briorick's Avatar
Originally Posted by danny4127 View Post
1 1/16 " on mine
Same here!!! I believe that IS the standard socket size on the Suburban water heater.
Rick & Brian
1 Happy Camper Pup ( Mya )
2017 Salem Cruise Lite 232RBXL
2004 GMC Sierra 2500HD LT 4x4 6.0 / 4:10
The best plans can be of those that happen in the spur of the moment!
Briorick is offline   Reply With Quote
Old 12-07-2016, 12:04 PM   #4
wmtire's Avatar
That has been my experience.
You usually want to make sure and use a six point socket on it also.
2011 Flagstaff 831 RLBSS
I've reported my DNA missing just in case it's found somewhere bad.
Old 12-07-2016, 12:27 PM   #5
Thanks all around. 1 1/16 6pt worked fine!
Charleston, SC
Old 12-07-2016, 02:27 PM   #6
I used a marker and wrote drain 1 1/16", now I don't need to remember what size I need, marked on the inside of the water heater door.
deadeye is offline   Reply With Quote
Old 12-07-2016, 02:32 PM   #7
D_B Travelers's Avatar
Yes, X8 on the 1-1/16" socket. Also, once I have it out, I brush the threads with a small wire brush to clean off the rust and debris before leaving it. When I start to reinsert the anode I wrap the threads with teflon tape which makes it easier to get it started straight. Holding up the far end of the rod while trying to get the threads started may increase your vocabulary, just do not have children or those easily offended close by.
Oh yes...DO release the water pressure BEFORE you unscrew the anode rod. Yes, you are correct on guessing how I know this. On the upside, the inside of the water tank was really clean after the pressure blowout! Oh boy...not so much my shirt!
D_B Travelers - 39 nights in 2018, 58 nights in 2017. [U]1st love: 2014 TT WJ3001w, now 2016 40' FW SOB, 2015 GMC 3500HD CC DRW Duramax, TST 507rv TPMS.
"Happiness? A good meal, a good cigar and a good woman - or a bad woman; it depends on how much happiness you can handle."
George Burns (1896 1996)
D_B Travelers is offline   Reply With Quote
Old 12-07-2016, 02:47 PM   #8
wmtire's Avatar
You know, I have that same shirt.
http://www.forestriverforums.com/for...dea-52704.html
Old 12-07-2016, 02:55 PM   #9
DB,if you use a 6pt x1/2" drive socket and lay newspaper across the socket and push the A ROD head into the socket this will give you a tight fit, now insert a 6" 1/2" Drive extension and you have a long handle to avoid all the bad words! Youroo! !
Old 12-07-2016, 03:24 PM   #10
Well, MR. Smarty Pants, isn't that a good idea! I will definitely have to give that a try when winter is over in a couple of months. ( Texas...Pfffft) I can always depend on the sheer pin falling out of the rear stabilizer shaft to assist the vocabulary!
Thanks!
Old 12-07-2016, 06:33 PM   #11
Other languages
I always use Italian, Slovak or Polish when dissecting or reassembling such things. Keep them guessing.
weatherguru1 is offline   Reply With Quote
Old 12-07-2016, 07:42 PM   #12
Best I could do would be Pig Latin! 🐖
Old 12-07-2016, 09:01 PM   #13
I believe those shirts are called "drip dry, wash and wear".
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
retiredcamper47 is offline   Reply With Quote
Old 12-07-2016, 09:25 PM   #14
To help steady the anode while entering it in the nipple on the bottom of the WH, I filled up the inside of my socket with a piece of styrofoam leaving just enough space so that the bottom of the anode nut is flush with the end of the socket when you slip it on (works like a very shallow socket). I also use an old toothbrush to clean up the threads in the WH nipple prior to inserting it. You'd be surprised how much trouble a little bit of corrosion / debris can make in a taper fitting. Makes all the difference in the world when trying to reinsert the anode.
2010 Wildwood XLite 26BHXL
2013 Ram Outdoorsman 5.7l
Ontherock is offline   Reply With Quote
Old 12-07-2016, 09:27 PM   #15
mike.t's Avatar
Shirt? It blew that white crap 20'. All over the front of my garage and part of the house not to mention the anode rod hit me just below the elbow.
2009 Ram 3500 Mega Cab
2018 Wilderness 2450FB
2014 Dodge Durango
2012 Dodge Challenger R/T
"If you can't fix it with a hammer, you've got an electrical problem"
mike.t is online now   Reply With Quote
Old 12-08-2016, 09:48 AM   #16
Well Mike, I wasn't being completely truthful in saying my shirt was all that was effected. Seems the Class A in storage next to me won a free partial carwash and, while I didn't get hit by the anode, it did land about 4' from the water heater. I had to go find towels to clean the white crap off of the guys Class A, then start cleaning up myself. I wonder if he ever noticed how clean a 10'x10' spot on his rig was? Seems he moved spots about a month after that.... Actually it was for sale and he sold it, so it wasn't my free wash that caused him to move.
I do feel so much better after you other guys have fessed up to the same thing.
Old 12-08-2016, 10:55 AM   #17
Sc00ter's Avatar
Lol, had the same soggy shirt myself in October. About a week later while in the front yard I heard a whoosh followed by choice words. My neighbor was standing there anode in hand wearing the same attire.
2015 puma 295bhss
2009 ram 3500 6.7l ctd
Sc00ter is offline   Reply With Quote
Old 12-08-2016, 11:02 AM   #18
geezer with gadgets
757Dave's Avatar
Don't have to ask you how you know...
Yes, same shirt, pants, socks, and shoes! I called it my RV baptism.
Sent from my Atari 2600
2011 Sunseeker 3170ds "Ladybug"
2017 Jeep Grand Cherokee TOAD
Days camped 2015: 37; 2016: 66; 2017: 86 2018: 57 2019: 30
757Dave is offline   Reply With Quote
Old 12-08-2016, 11:05 AM   #19
Anode Epidemic!
Perhaps this is a seasonal Fall epidemic? A lot of stories from so many RVers makes reading this forum so much fun! Saddened to know I wasn't original, but good to know I have a LOT of company on this little event.
Old 12-08-2016, 11:35 AM   #20
I've never had to use the pressure relief valve on my HWH. We only turn it on when we need it (mostly for dishes) so it's not in use all that much. The water is always nice and cool when I remove the anode.
Iwritecode is offline   Reply With Quote
heater, hot water, suburban, water, water heater
