Old 12-06-2016, 03:07 PM   #1
Storing Water Filter
After winterizing is possible to safely store the the water filter for reuse or must a new one always be used?
wmdave17 is offline   Reply With Quote
Old 01-15-2017, 10:14 AM   #2
It's up to you. If it's a cheap filter replace it, if it's costly save it. Or depending on the model and type take the filter and get it out from inside before it breaks and then you can buy a new filter housing and use cheaper filters.
2019.5 Rockwood 2509S
Toddupton is offline   Reply With Quote
Old 01-15-2017, 10:23 AM   #3
bubbles's Avatar
If it's a CC-10 type filter and only been used about a week or two I put it in the freezer till needed in a few months. Does not affect it at all. They are inexpensive but hey. If it has been used a few months I toss it.
Old 01-15-2017, 10:31 AM   #4
Flybob's Avatar
I use an external filter and replace it every season as they are inexpensive. In between trips I store it in the home fridge. Maybe overkill but as an experiment fill a glass with water from your RV tap. Let it sit in the sink in between uses of the RV. The prior to next outing, look at the glass and decide if you are OK with the water. Especially in the summer, lots of things will grow in it.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 01-15-2017, 10:36 AM   #5
bubbles's Avatar
When I said "freezer" I was talking about my home fridge freezer not the rv freezer.
Old 01-15-2017, 10:44 AM   #6
Ford Idaho's Avatar
One filter, one season.
One season, one filter.
Either way is fine with me.
Old 01-15-2017, 11:24 AM   #7
Thanks!!!
Thanks for the info, much appreciated.
water, water filter
