What SHURFLO writes about the bypass:
“NOTE: By-pass adjustment should only be performed by a professional techni- cian with proper gauges and equipment.
The by-pass is a spring loaded dia- phragm that opens up allowing water from the discharge side back to the inlet side. The by-pass is set to begin opening at about 40 psi and creating full by-pass at about 62 psi (lower pressure pumps will vary depending on the by-pass and pressure shut-off settings). The pres- sure switch on the pump is set to shut off at 55 psi. If the switch or by-pass
are adjusted too much, the by-pass and switch shut-off can overlap and THE PUMP WILL NOT SHUT OFF. Screwing the switch screw in clockwise will raise the shut-off pressure. Unscrew- ing the switch screw counterclockwise will lower the pump shut-off pressure. Screwing the by-pass screw in will raise the pressure at which the by-pass starts and raise the full by-pass pressure. Unscrewing the by-pass screw coun- terclockwise will lower the pressure at which by-pass starts and lower the full by-pass pressure.
WARNING: If full by-pass is reached before the shut-off setting, the pump will not shut off. Full by-pass pressure setting should be at least 10 psi higher than pump shut off pressure.”
The bypass will not help solve the problems associated with thermal expansion.
Bruce
