10-16-2020, 01:54 PM
Suburban SW6DEL Switch Frozen
If this water heater is 2 years old I will eat my shorts, but that aint gonna fix baby.
It would seem that the gas part of this heater just isnt working and I cant turn the electric switch off at the unit because it is frozen in the on position (see below).
All the pictures Ive seen of shiny new units also seem to have some way to adjust the air draw with an adjustable flue vent, this just has a window.
I know better than to remove the unit for servicing while connected to water or electric / gas services so I can at least look at the guts and perhaps change that rocker switch.
Anybody else got any advice before I flush the gas line and get knee deep into something I cant handle?
Working with a Flagstaff FD 2018.
10-16-2020, 02:02 PM
This is a pretty common problem. I had the same thing happen to me. Here is the thread I started about it. Hopefully it will give you some ideas:
https://www.forestriverforums.com/fo...ce-182725.html
Bruce
10-16-2020, 02:25 PM
Hey sorry to bother you buy I click your thread and all it does is lead in a circle back to plumbing. New here so clearly I am doin somethin wrong.
Any idea?
Originally Posted by nomad297
10-16-2020, 02:33 PM
Any idea?
The link takes you to an older, previously posted thread... did you read through it for ideas like was suggested?
Days Camped: '18=51 ☼ '19=58 ☼ '20=110 ☼ '21=15
10-16-2020, 02:35 PM
Try typing “Plumber in Need of Plumbing Assistance” in the search at the top of the page and see if you can find it there.
Bruce
10-16-2020, 03:24 PM
For your reference:
2016 Salem 27RKSS
10-16-2020, 03:53 PM
Ok so here is the "funny part."
You cant get there from here so to speak. My Android 11 Pixel 3a wont load the page off the app.
My laptop will from Google.
Putting a doggie time out pen together for our Malimois so I only read a little bit, but boy! 3 pages of discussion pardon me if I rush to the conclusion of design flaw making me wish Radio Shack was still a thing?
Thanks for the assists.
I figure by the time the Spring comes I will be at the point of deciding what to pull her with.
Probably going to build out a 90 something Chevy van with an 8 cyl engine and a heavy duty transmission / torque converter... something I know about and can readily find junkyard parts for.
Well anyways, thanks for the assist.!
10-16-2020, 04:59 PM
You should have a circuit breaker in your power center. Use that to shut off the 120 v AC. Frozen switch is very common. I just used my breaker for 3 years once my switch stuck.
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32, 2020-41
10-16-2020, 06:24 PM
2020 Georgetown GT5 34H5
10-16-2020, 06:29 PM
I turned off my water heater breaker, used a small screwdriver to pry the switch out of its rectangular hole, removed the switch, jumped across the wires just to test, turned the breaker back on and the heater worked. Later I paid $5 + tax at a local RV service center and replaced the switch. I don't carry a spare switch but I do carry a little piece of jumper wire.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 = 108; booked = 32
10-16-2020, 07:00 PM
Mine is also frozen. Fortunately it is in the ON position. It use the switch inside the fiver to turn the water heater on and off.
Tom & Renée
Durham, NC
2015 Wildcat 295RSX
2018 Ford F-350, 4x4, Diesel, CC, Long Bed
10-17-2020, 02:46 PM
ARLO
I leave the switch and all the time. Between the circuit breaker and the water heater I installed a switch with the pilot light to turn it on and off from inside the trailer. It works great. A little bit of work but well worth the effort.
10-17-2020, 04:04 PM
Unplug
Most (maybe all) RV water heaters are not hard-wired. They use a standard three-prong 120 vac plug which plugs into a wall outlet. That's reachable from the same place you go to access the bypass valves.
If the switch is frozen in the "on" state, a temporary measure is to plug a computer outlet strip between the outlet and heater plug. Use the switch on the strip for control. Or, as you state, use the circuit breaker.
Larry
10-18-2020, 03:42 AM
Your WH will run on Gas, Electric or both at once.
If you are plugged in at a campground you can turn the gas off and use 100% electric on their dime. You can turn the gas on and you will get a faster recovery.
It is not necessary to turn the electric off to use the gas.
I don't see the problem.
Jump the switch only if it is stuck off, if it is stuck on leave it alone.
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
