System use & water pump
Have a 2019 Chap 360IBL. Had it for 1.5 years and always repairing little things on it. Latest is my water pump seems to be acting up. It seems louder, and sometimes not running when I think it should be
Water panel is attached. Assume we are hooked up to water at a campground. The way I understood it, even if your hooked up and the campground water is on, if you go to "system use", your going to be using your own freshwater supply.
If I go to "system use" (leaving CG water on), I can open a faucet and get normal campground pressure. Turning the water pump on or off does nothing different (it doesn't run, because the pressure is already there). If I shut the CG water off, the pump acts somewhat erratic.
To help with my troubleshooting, I'm turning to fellow owners! If your on "system use", CG water pressure should not enter your system... is that correct?
