09-28-2022, 12:24 PM
T-Handle
Good afternoon everybody does anybody know how to fix the gray water T handle pictures are included. The black Waste is above to the right. Looks like I should be able to replace pretty easy
09-28-2022, 12:40 PM
Those handles screw onto the rod that goes into the valve and you can buy replacement T-handles almost everywhere that sells R/V parts and online.
09-28-2022, 12:49 PM
Part-Time Campground Host
^^^X2^^^
And they even have metal ones!
Craig & Cath
Days camped since 2015(retirement): 1687
09-28-2022, 01:27 PM
that being straight down lets all the crap settle in the valve slide groove. move it to horizontal. drill a tiny hole sbove slide rod ,just big enough for a spray lube red tube . keep it lubed . be sure to put a screw in hole or it will squirt on you. paint top of screw white for easy recognition of where it is located.
09-28-2022, 01:43 PM
Moved thread from the General Community Discussion section to the Plumbing and Water Systems sub-forum since the OP's questions are specific to that sub-forum.
Sent from my SM-G781U using Forest River Forums mobile app
09-28-2022, 02:01 PM
Sorry dude but you have no idea what I'm talking about thanks though
09-28-2022, 02:33 PM
Are you responding to my post?
You should quote the post you're responding to.
09-28-2022, 03:09 PM
Amazon has replacement valves with metal handles. Easy one wrench 10 min job.
Peace!
Dan & Rita D
09-28-2022, 03:12 PM
Sorry. Not u. Thomas that drill hole and spray lube
09-28-2022, 03:16 PM
Got it fixed. Thanks guys. Have a good day
09-28-2022, 03:35 PM
Check out this video. It will explain Thomas' post.
And BTW I've been doing this for years and it works. Still using the same valves our camper came with. Use stainless steel screws.
Craig & Cath
09-28-2022, 05:41 PM
If you read my post I was talking about how to replace the broken t-handle the broken t-handle not how to lubricate anything the broken t- handle. I needed to know how to replace it BECAUSE IT WAS BROKEN
09-28-2022, 05:43 PM
Forget it. I replaced the T-handle
09-28-2022, 05:54 PM
If you spend any time here, you’ll see that members give helpful tips that are not merely crisp answers to questions asked. We use what info we can and skip what we don’t need. We don’t always complain that someone gave too much information. The possibility exists that one ear of the T-handle broke off because the handle/rod/valve didn’t slide smoothly.
I’ve seen T-handles work even with a broken ear.
09-28-2022, 06:13 PM
Great video! I bookmarked it.
Astros1
2021 Forest River Sunseeker 2400B MBS
09-28-2022, 06:35 PM
very helpful, thanks!
2021 2205S Rockwood Minilite
2019 F 150 Lariat 3.5 Eco Fx4 Max Tow
Equal-i-zer WDH, 1809 lb payload
09-28-2022, 07:22 PM
X2 Great video
I never thought to do this, lucky I never had an issue I guess.
2019 Chevy 3500 4x4 Crew Duramax
2021 Wolf Pack Toy Hauler
2019 Street Glide
2023 Road Glide ST
09-28-2022, 08:23 PM
I agree. This looks like two potential problems to me. (in addition to the broken handle)
1) it seems to be that the T-handle is pointing straight down at the ground. This puts the handle in an unprotected position and might well be the lowest point on the undercarriage. In addition to the handle breaking off again, I could foresee a piece of road debris breaking the whole valve off.
2) With that handle pointing down, it means that the blade in the valve slides down to open and up to close. When the valve is open, the blade and the slot that it slides into is a low point in the drain path, which could cause it to collect debris and drag or even jam.
The suggestion to remove the valve, rotate it 90 degrees and bolt it back on solves both of those problems, while probably making the T-handle easier to reach and manipulate. If my trailer had come like that, I think I would have rotated that valve long before the handle had a chance to break off. Just because I'm lazy!
But hey.... you can lead a horse to water....
-Qwkynuf
2003 F150 Supercab 4x4, tow pkg, 3.55 gears
2020 Flagstaff Micro Lite 21DS
10-03-2022, 06:41 PM
my problem with those valves is that they tend to leak a bit, even new ones... makes for a surprise when you take the cap off to attach a drain hose...
Bill
10-03-2022, 09:11 PM
Well said Dan and thanks Thomas ho for reminding me
Even though the originator of this thread didn't appreciate the friendly advice from Thomas ho - I did. It reminded me I need to do the lubrication on my T-handles. So I am thankful for that.
_____________________________________
2119 Flagstaff MicroLite 21DS
2002 F150 FX4 5.4L V8
