Originally Posted by youroo
Our Flagstaff TT has heat pads on ALL 5 Tanks plus the lines and elbows going to the Dump valves! They are All 12Volt and All activated by 1 Switch! All are Temp controlled for On and Off while heating,enclosed underbelly! Youroo!!
My MicroLite has heat pads on three tanks and heat pads on the discharge pipes of holding tanks.
I test current flow by turning on my tank heaters and looking at my Victron Battery monitor.
The heaters on the discharge pipes are small and only draw about 7 watts. They have NO thermostats built in and will draw about an amp or less each.
The tank heaters need temps lower than ~40 degrees before they'll switch on. When I tested them one frozen morning I found that only 2/3 the estimated current draw was going to the heaters. Just under 10 amps and if all three were running it would be just under 15 amp. The Fresh water tank evidently had enough retained heat from the day to keep it's heater pad turned off.
The only real way to test tank heater pads is to first make sure power is getting to them. Check for 12 volts at the pads with switch on and if no power, correct that issue first.
Next, wait for a nice cold, freezing day, and turn tank heaters on with a means of measuring current flowing to them.
When ALL heating pads on my trailer (3 tank pads and two "elbow pads") I expect to see 4.8 amps per pad and ~1 amp per elbow heater. If not I can use my clamp type ammeter and check individual pad current to see which pad isn't working. IMPORTANT, the pads must be at or below freezing temps and if tanks are filled with liquid the amount of liquid will take varying amounts of time to cool below "activation temp" of the thermostat.
On that note, I'm expecting 20 degree AM temps and my tanks are empty. Good time for me to test my own
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
