We have a 2020 Vibe 28rl and we have our new rig at the lake for the 2nd time with about 5 people in it. We've been here about 4 days now and I checked the tanks this morning and I had empty grey tanks, since the valves are open, the black tank still reads empty and the fresh water tank reads 2/3 full which is not possible because no water has ever been put in it. So what gives???
Welcome from New Jersey ,Do you happen to know the capacities of your tanks? My 1st camper has water in the fresh tank ,The dealer put it in to test things,I would close the grey towards the end of your trip so you can flush out your hoses, Does the Vibe have the shower miser? Have you dumped the black tank ? Do you have clear elbows on the drain hose so you can see what's coming out ?
I don't know the specifics of your model RV or what options you have but I will tell you a story from mine that could possibly have happened to you. our shower has a water miser valve where you can turn the valve and the water will return to the fresh water tank. The idea is that you do that until the hot water gets to the shower. My daughter used that thinking she was turning the water off while she washed her hair. In reality, she was sending water from the hose hook up to the fresh water tank. Is it possible that someone in your group took a shower and did the same thing?
Also a possibility that since its a new camper, the fresh and black tank wire connections on the back of your display are switched. The fresh tank wire is blue and the black tank wire is brown.
Make sure you have a problem with the wires by verifying there is water in the fresh tank by opening the fresh tank drain before you start swapping them
Here is how the wiring is supposed to be connected and a troubleshooting guide for the generic system.
Hope this helps you troubleshoot your issue.
HAM CALLSIGN - KC3FFW
X2
Bruce
The freshwater tank is 40g and the black is 30g. We take navy showers and try to use the campground bathroom as much as possible. No clear elbows and yes, I plan on closing the grey tanks soon to start collecting water prior to dumping in 2 days.
I am unfamiliar with a "shower miser". Now, we do have the shower head with the button to turn off the flow of water while you soap up like all other trailers have.
This was my first thought, just a couple of switched wires.
