Tank sensor question (technical)
I was a little surprised while getting under the trailer to address a water filling issue. I was aware that there were sensors in the tanks that sense the water conductivity to detect the levels, but I assumed there was a wire for each probe. Looking at the wiring, I was surprised that the upper 3 sensors are all wired together to one wire, and the bottom one appears to be wired to ground. Is that correct? Looks like it's trying to measure the combined resistance of all the probes as each probe touches water; I was under the impression it just sensed that if any one of the probes has any conductivity, then the water was at that level.
2023 Wolf Pup 14CC
