Originally Posted by mgb1969
Hi, The grey water sensor doesn't move off of empty. I am not sure where the tank is located or how to get to it. I did a little looking on utube and think I could trouble shoot if I could get to it. The black and fresh look like they are at least in the ball park.
Could you take a picture of the wire connections on the back of your display? It is possible the wire on the display from the gray tank has broken. You are looking for the grey wire.
If that is ok, then you will need to swap the gray wire with the blue (fresh water tank) and see if the problem moves to the fresh water tank.
If it moves, the problem is at the tank and you will need to drop the Coreplast plastic belly covering to access the grey tank bottom (lowest) sensor (the tank ground) and see if the white ground wire has broken.
The ground stud should be the one at the lowest point and by itself on that side of the tank. (left in this photo)
The wiring diagram and trouble shooting procedures are attached.
Oh, don't forget to swap the wires behind the display back.
