Old 05-17-2020, 02:05 PM   #1
Tankless water heater
I have a 2012 Wildcat with tankless Wildcat. It does not seem to get very hot anymore. When it is very cold out, it gets Luke warm. As it warms up outdoors, it warms up, but not hot, hot. Any suggestions?
Chappy319 is offline   Reply With Quote
Old 05-18-2020, 10:35 AM   #2
Trobec's Avatar
What brand of tankless heater? On my girard 2G WHAM tankless heater there is a dial on the bathroom wall that controls the flame in the heater. I usually have it set at 1:00. Also I do not use the cold water at all. If the water is too hot I turn the the hot water nob up. If itís too cold I turn it down a little. This regulates how fast the water goes through the heater. Slower the water goes through, the hotter it will be. Faster=cooler.
Trobec is offline   Reply With Quote
Old 05-18-2020, 10:37 AM   #3
Trobec's Avatar
Also make sure you have the air out of all the hot and cold water lines. Donít forget your outside shower as well.
Old 05-19-2020, 08:14 AM   #4
Iím not sure on the brand, I will have to check, I only have a switch with high and low.
heater, tank, tankless, water, water heater
