We are using a ware pressure regulator because the factory said to limit the pressure to 45 lbs.
I understand what you are driving at, but when the water pressure is to low the controller turns off the heater. The control panel in the rig shows the water temp, when the heater is on, and the status of the propane flow to the water heater.
When we turn on the hot water it heats it to 120-125 degrees. However, we have it set to 105
Morgan
2023 Ford F-150 Lariat 4x2 SuperCrew, 3.5L EcoBoost
2023 East to West Alta 2600KRB
