03-03-2020, 12:28 PM
Toilet fills an inch or two after flushing (then stops)
All,
In my last TT, when you flushed the toilet, the water turned off as soon as you released the foot pedal. I kept telling my kids (to no avail) to put an inch of water in afterwards, just to help seal it from gas rising through.
Traded for a new 5er, and kept doing that out of habit. When I would go the next time, I noticed that the 1" I put in was now 2-3". I ended up flushing again, walking away, and within a few minutes there was 1" or so in there again. When I winterized, you could really see the pink stuff slowly dribble out of holes around the rim, even after releasing the pedal.
When I first noticed this, I was concerned the toilet would slowly fill and overflow. But that doesn't happen, thankfully! I guess this is just something that is happening as pressure is relieved in the lines. Has anyone else experienced this?
03-03-2020, 12:33 PM
Might help to quote your make and model of toilet.
2011 Traverse LT, 3.6L, FWD
03-03-2020, 12:36 PM
Ahhh, something you'd only hear/read on an RV forum . . .
(Just can't imagine that line ever coming up at a cocktail party or Thanksgiving dinner!!)
2015 Berkshire 34QS
03-03-2020, 12:51 PM
Our toilet does that also, and has from day one. And if I'm not mistaken, our previous RV did that also. Don't know what toilets they are/were, just that they are porcelain.
Had this RV for 8 years and the toilet doing this has never caused problems. I figure it's just how the valve works, never gave it much thought.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
03-03-2020, 01:41 PM
Originally Posted by jj95
... I ended up flushing again, walking away, and within a few minutes there was 1" or so in there again. When I winterized, you could really see the pink stuff slowly dribble out of holes around the rim, even after releasing the pedal.... Has anyone else experienced this?
There are some toilets that have a caution about that very thing in the manual. It states that the water could flow for several seconds to a minute after the valve is released. Ours does it a little bit but only a few seconds.
Gotta go campin!
03-03-2020, 01:49 PM
We have a Dometic Model 310. When out last summer we noticed this also and I ordered a new fill valve for the toilet and replaced it. It still occurred, so I called Dometic and was told residual water in the toilet rim may continue to slowly run into the toilet for up to 20 minutes (although not under pressure) and this is noted somewhere in the manual.
2018 Cherokee Arctic Wolf 265DBH8
Lippert Turning Point Pin Box - Reese Pro Series 15K Fifth Wheel Hitch
2018 Ford F250 4x4 SuperCab, 6.2L Gas, 6'-8" Bed
03-03-2020, 02:12 PM
Good to hear, thanks! It sounds like I need to read the manual! Not even sure what model it is either, other than porcelain and round!
03-03-2020, 02:24 PM
If yo have a Dometic toilet they slowly add a few inches after flush is complete.
Gary and Donna
2005 Cardinal 33TS-LX
Trail Air pin box
Center Point suspension
2018 Ram Laramie 3500 6'4" box 2WD
Demco AutoSlide 18k
03-03-2020, 02:54 PM
Probably a good thing
An inch or two is probably a good thing for keeping the flush seal on the toilet, clean and in good shape.
Directions for winterizing also instruct to add a little antifreeze to the black tank to keep the drain seal and drain pipe from freezing.
It also states to add a splash to bowl to protect the seal.
2016 Rockwood 2109S
2014 RAM 3500 - Cummins
165 Watts of Rooftop Solar
03-03-2020, 03:05 PM
I have a Dometic 310 in my Dynamax Series 4. The toilet does this also, but not all the time. Not sure but it seems to vary by how quickly I release the foot pedal. If quickly released it usually does not flow after the flush.
03-03-2020, 03:06 PM
I had to replace my dometic toilet and I did read the manual. It runs for 30 seconds after you flush.
03-03-2020, 05:06 PM
All,
That is normal for newer model toilets. You no longer have to add water manually after flushing. The source of the water is that left in the upper area of the housing after the valve closes. Intentional by design.
2017.5 Cedar Creek 34RL2
2018 F-350 Lariat CC SRW PSD 4x4
USMC Fighter Pilot (Ret)
03-03-2020, 05:08 PM
Strange that "required" a new toilet. A valve change would have fixed the problem. Available on Amazon for under $20, and easy to do for anyone who can operate a screwdriver.
03-03-2020, 05:18 PM
For most toilets the water that continues to flow into the bowl after foot lever is released is merely that water that is between outlet in bowl and the valve. This has always been present in every RV I've owned or rented and the amount varies from model of toilet to model.
03-03-2020, 05:55 PM
After Flow is based on several factors Size of Rim Jet holes /PSI of supply water/Amount of Scale/Crud in Reservoir Rim area! Porcelain toilets are more prone to this because of the Hand applied Glaze! Youroo!!
03-03-2020, 06:26 PM
Normal.
2017 FR3 28 DS
03-03-2020, 11:17 PM
We just recently changed from a Dometic 310 to a 320 to get the elongated seat.
The 310 put in about 1" of water, the 320, about 2" of water. Both normal.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
03-04-2020, 12:27 AM
Normal. Think about it. You flush, water runs from the rim down the sides of the tank and down the drain. You release the flush valve, the water turns off but the water that was in the flush rim and still running down the bowl sides does not stop flowing just because you release the flush valve. It continues until there is an inch or two in the bowl and no residual water in the rim.
03-05-2020, 10:05 AM
Toilet
All,
It's designed to do this to help prevent odors from getting past the rubber seal.
03-09-2020, 10:04 PM
I woulder if elevation has anything to do with it?
