Old 10-27-2020, 02:38 PM   #1
Toilet overflooded
Still open late in WI in October. Came back up after 3 days and the campground water, when I turned it on, was not flowing after the colder night. So, I have the fresh water tank full and turned on the pump and heard it running more than I would have thought it should run to pressure the lines. Then, I shut off the pump, checked the campground water and it was still not flowing. So, I tuned on the pump again for just a bit and it kept running! Shut if off and then the next thing I found was that there was water all over the bathroom floor! I thought for sure that a water line had burst under the bathroom sink, but then when I lifted the toilet lid, I saw that the bowl was full and the water was overflowing from the toilet bowl!
Sierra Destination Camper - 2017 401 FLX
dcavaiani is offline   Reply With Quote
Old 10-27-2020, 03:00 PM   #2
Sounds like the toilet valve broke internally when it froze. Water ran into bowl without the "flap" being open.
Valv
Some good news (maybe), a replacement valve for your toilet is a fairly easy fix and valves are often stocked at Dealer's or RV Supply Stores. Also on Amazon. Figure $30-$40 for a replacement if you do it yourself.
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
Old 10-27-2020, 03:20 PM   #3
I don't know if it broke or if it was just a bit "frozen" until we warmed up the camper today, but it seems to be working well now. I had the camper temp set at 40 degrees which it was at when we arrived today.
Old 10-27-2020, 03:38 PM   #4
2004 Nissan Titan
Old 10-28-2020, 03:20 PM   #5
Don't know if what could maybe be a problem IF I have the fresh water pump on AND also have the campground water supply turned on. I may have done that cause the campground water supply was temporarily frozen up a bit.
