Old 06-05-2023, 12:43 PM   #1
Toilet Seal
Water will not stay in the toilet bowl
Toytrain1 is offline   Reply With Quote
Old 06-05-2023, 01:01 PM   #2
NMWildcat's Avatar
Don't know what toilet you have, but most have a rubber seal that dries out over time. Either replace it, or try some plumbers silicone faucet grease on the rubber seal.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 06-05-2023, 01:08 PM   #3
You can also use some vaseline in a pinch.
KKonyha is offline   Reply With Quote
Old 06-05-2023, 01:13 PM   #4
NMWildcat's Avatar
You could, but petroleum products will damage rubber products. Silicone products are always recommended for rubber.
Old 06-05-2023, 01:23 PM   #5
NMWildcat's Avatar
Another thought. If you are going to coat the sealing surface with plumbers grease, first, clean the bottom of the seal (the sealing surface) as well as you can. I usually use a wet paper towel with Dawn.
Oh, and welcome to the forum!!
Old 06-06-2023, 07:02 AM   #6
Don't rule out just cleaning it. Mine was dry this morning and I just leave enough in to cover the bottom.
Thru some vinegar in it to knock a little hard water deposits off although they were minor.
Cleaned the toilet and ran the brush past the seal a couple of times.
Holding water now. Think a piece of crud just was keeping the seal up some.
2022 Rockwood 2511S
2018 F150 3.5 Crew Cab
Max Tow Package
Husky CenterLine WDH
GolfingDave is offline   Reply With Quote
Old 06-06-2023, 08:59 AM   #7
I replaced the rubber seal last year. Took about 5 minutes. Link:
I got a 2 pack of seals off Amazon. I don't have a link but this is what I ordered for our Dometic toilet.
Sikawai 2 Pack 385311658 Flush Ball Seal Replacement for Do-Metic 300/310/ 320 RV Toilets
seal, toilet
