09-21-2020, 01:06 PM
#21
Kanadian Kamper
Originally Posted by Gmar60
You have the dreaded cone of poo. Solids have gathered where toilet drains into tank.
I agree. A lot of seasonals......and I suspect that’s the type of RV we’re trouble shooting here......leave the waste gates open all the time, instead of filling the holding tanks before emptying. The gray and black tanks are HOLDING tanks, NOT SEPTIC tanks.
Ken and Terry
09-21-2020, 02:16 PM
#22
Does the unit have 2 bathrooms and possibly a 2nd black tank?
09-21-2020, 06:22 PM
#23
Another adventure awaits!
Toilet will not drain - end post
Thank you all for your responses ... truly appreciate it ... have tried everything regarding snaking, poking, prodding ... and yes, pulling the black tank lever ... but as that is not the problem does not really matter ...
Tech is coming in this week to take a look ...
2018 Columbus Compass 377MBC
2013 F250 4 x 4 Supercab
09-21-2020, 06:24 PM
#24
nope ... only the one ... and it is not the black tank that is the issue ... the black tank has been cleaned, dumped and is empty ... the toilet will not drain .
09-21-2020, 06:56 PM
#25
Let us know what you find. It is unusual if the tank is emply and cleaned that the water in the toilet would not drain.
Good Luck !!!!!
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
09-21-2020, 07:04 PM
#26
The toilet will not drain because it’s entrance into black tank is blocked. Had this same issue when on first few days of travel we did not use enough water. The paper and solids drop onto bottom of dry tank and form a mound. Mine was easy to clear because it is a straight drop from toilet to tank. I was able to use a stick and spray wand to get said mound broke down. You may need to poke around in tank from drain end. Wear protective suit and face shield! Yuck [emoji90] [emoji90]
09-21-2020, 07:28 PM
#27
maybe try a wet dry vac with a long hose and suck the water out that way. Then maybe you can see what the clog is and maybe you can get it out that way
2019 Flagstaff 26 RBWS
2015 GMC Sierra 1500
2019 camp 17 nites. Bill,Alley and are two kids Sierra,Ivy. 2020 camp 9 nites
09-21-2020, 10:17 PM
#28
We know its blocked, just trying to figure out a way to ascertain where blockage is ... have run snake down, at least 6' each time, several times ... and no, she is not pulling the wrong lever ... but thank you
Use a camera and you may be able to see what's going on in your drain system.
Have you tried snaking down the roof vent?
09-22-2020, 03:59 AM
#29
Just because you drained the black tank and flushed it afterward, unless you looked inside the tank from the toilet with a flashlight to verify it was empty, it may not be empty.
As was stated previously, a mound can build up inside the tank below the toilet pipe and block the flow from the toilet to the tank.
This is caused by not flushing with enough water, leaving the tank valve open to the sewer which allows water to run out but leaves solids or both.
The tank flush, unless run with the black tank valve open for an hour might move the mound but possibly as one big clog. There are wands that you can connect a hose to that you stick down the toilet that will help break up the mound.
Good luck!
Kirk
2017 Forester 3051S
09-22-2020, 06:04 AM
#30
"On the road again"
I'd go buy a cheap, old-fashioned plunger. Step on the pedal to open the trap and plunge away.
This same thing happened to us once in our Columbus (previous fifth wheel) and the plunger did the trick. Turned out it was evidently a toilet paper blockage.
Robert & Estha Shiflet
Georgetown XL 378TS
Jeep Gladiator Willys Tow Vehicle
09-22-2020, 10:44 AM
#32
Toilet won't drain
Thinking she pulling the wrong level out (gray tank)not black
09-22-2020, 11:23 AM
#33
I feel like we've ruled that out already.
09-22-2020, 11:58 AM
#34
I mean, unless it's a non-standard install the toilet literally dumps straight into the black tank. If the toilet doesn't drain then there's a blockage, either in the section of pipe that connects the toilet to the black tank (again, a straight shot) or there's a pyramid of waste. It's really not a complicated issue to troubleshoot, it sounds like the OP/owner are making assumptions and aren't taking the time to just grab something, even a stick, and stick it down the hole in the toilet while the valve is open to see what they feel and what happens.
Am I missing something?
2017 GMC Canyon - CCLB, 4x4, 2.8L Duramax, ARE Z-series shell
2013 Shamrock 21SS
09-22-2020, 12:04 PM
#35
Sounds like the tank is still full and didn't drain properly the last time.
09-22-2020, 12:11 PM
#36
Also, just because the tank was drained and "flushed" doesn't mean it got everything. The pyramid of solid waste isn't something you just wash/flush away no matter how many times you flush the tank.
If you manage to dislodge the pyramid from the bottom of the tank without getting it to break down then it's likely plugging the tank drain. You think the tank is empty because nothing comes out of the drain but the tank is full.
Ask the owner if they leave the drain valve open most of the time or not. If they do then the solids will build up while the liquids go down the drain and over time you get the pyramid. The black tank should be allowed to fill and proper use of chemicals will help break the solids down so that this build-up doesn't happen.
2013 Shamrock 21SS
09-22-2020, 01:34 PM
#37
OP claims they ran a snake down 6'. I can't imagine the pipe between the toilet and the black tank is more than that.
Hey folks ... need some help ... toilet will not drain when stepping on foot pedal ... the tank is empty ... just cleaned it ... have run a snake down, 6', and there is nothing blocking ... step on foot pedal, trap opens but water goes nowhere ...
It is a theta pedestal model ...
09-22-2020, 02:35 PM
#38
It's clear that some members aren't reading all the thread posts, based on recent responses.
09-22-2020, 02:42 PM
#39
Shall do ... thank you
09-22-2020, 02:45 PM
#40
They do not leave it open ... why ask for problems ... they are experienced RVers and have never had an issue before ... all was working fine ... emptied and cleaned tank ... incl using power washer ... toilet was working fine ... then all of a sudden it did not ...
