09-22-2020, 02:47 PM
#41
Another adventure awaits!
No ... we are experienced, knowledgeable RVers ... we do not leave our black tanks open even though we are "seasonals" ...
2018 Columbus Compass 377MBC
2013 F250 4 x 4 Supercab
09-22-2020, 02:54 PM
#42
Please use the QUOTE function so we can know to which posts your answers are referring. Thanks.
09-22-2020, 02:56 PM
#43
Well, let us know when you get it figured out. So far, a lot of things just don't add up, so this doesn't seem like your ordinary clog.....
Good luck!!!
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
09-22-2020, 03:36 PM
#44
Why not try a wet dry vac.
2019 Flagstaff 26 RBWS
2015 GMC Sierra 1500
2019 camp 17 nites. Bill,Alley and are two kids Sierra,Ivy. 2020 camp 9 nites
09-22-2020, 03:37 PM
#45
Frog-Toberfest Organizer
I had a similar problem. There was a clog at the bottom on the toilet side. I bought a section of pex tubing and used it to clear the issue out. That in turn created another problem. Whatever was causing the blockage broke free as a whole piece and blocked the black tank drain. I had to have a sewer truck come out and he suctioned it right out. I think our problem came because we used different tp than normal for a while due to the covid hoarding. Cost me about $70 to have it cleaned out.
So if hers was clogged and you used the snake the clog may have moved to the black drain like it did in mine?
2016 Vengeance 320A
2015 Chevy 2500HD LT 6.6L 4x4 ccsb Z71 trim
2012 HD Electra Glide
Andersen Ultimate Aluminum fifth wheel hitch V2
Days camped '16=43, '17=47, '18=57 '19=47 '20=47 '21=64 '22=62 '23=72 '24=0
09-22-2020, 03:40 PM
#46
Cheaper to use a wet dry vac
09-22-2020, 03:42 PM
#47
My black tank drain has a weird elbow in it and I couldn't get a vac house in there. On the toilet side the pex was maybe $6.
2016 Vengeance 320A
09-22-2020, 03:57 PM
#48
Why cant you take a flexbile garden hose and make a adapter to downsize the hose and use it that way.Thats how I clean my hot water take ast the end of the season
09-22-2020, 10:06 PM
#49
Originally Posted by bubbles
Seems that if there was a vent pipe issue opening the drain valve should allow venting.
Me too.
2018 Coachmen Leprachaun 210RS with DW, Nanuq the Samoyd puppy and the cat.
09-22-2020, 10:24 PM
#50
Toilet wont drain
Good luck!!!
Thank you ... will do ... even had park owner check it out and he is stumped...
09-23-2020, 06:05 AM
#51
We had friends that something like this happened but in their front bathroom, the drain pipe for the toilet was to long and reached the bottom of the tank and eventually clogged from poo and paper then would not allow anything to pass, just something else to consider. Good luck
2017 River Stone Legacy 38mb
2001 Kenworth T2000
2016 Smart for Two on deck
09-24-2020, 06:33 PM
#52
Maybe the pull that opens the gate broke and the gate isn’t opening.
09-24-2020, 06:57 PM
#53
Hose spreader
09-24-2020, 07:10 PM
#54
Originally Posted by wwdriver62
Hose spreader
This is definitely an unusual problem. I'm very curious about the cause.
09-24-2020, 07:28 PM
#55
Toilet
Had this exact same problem with a Rockwood 5th wheel. All was fine until water would not drain from toilet. Actually used a broom stick down the toilet and it hit something very solid, like maybe an elbow. After few solid hits with the stick it cleared. Still don't know what caused it but everything worked fine after that.
09-24-2020, 07:37 PM
#56
Thank you ... will let my friend know
09-24-2020, 08:49 PM
#57
Sewer king
If you have a clog you can’t clear buy a sewer King it goes on the end of a water hose. You put it down the toilet turn on water. It will seal itself and blow out any clog without coming back up toilet. Had to do mine several times before taking it in and finding out my sewer line into black tank was to long. They cut it off haven’t had any problems since..
09-24-2020, 08:57 PM
#58
Snake indicates nothing blocked, yet water is suspended in the toilet when valve is opened. If air is below that toilet valve and the valve is opened , nothing short of a lapse in gravity will keep what is in the toilet suspended like Magic, does not matter if the vent is blocked it’s going down maybe not as fast as you like but it’s going down. What is in the toilet will go down as the trapped air bubbles up. This smells.... sorry for the pun
09-24-2020, 09:02 PM
#59
Sewer vent on roof open ?
09-24-2020, 09:24 PM
#60
When we first purchased our RV we had a similar issue, the treaded poop pyramid.
We kept pouring near boiling hot water down into the toilet until it broke it up. We now fill the black tank with a decent amount of water before we start using it.
If the valve is open, and nothing comes out, yet the water in the bowl doesn't drain, there must be a blockage in the toilet or drain pipe from the toilet.
