Old 05-10-2021, 07:45 PM   #1
Truma tankless hot water
So I have Isata 3 series motorhome with Truma tankless hot water system. Had it winterized at camper inn, then I dewinterized it myself. Went to use it this weekend and the power was on at the panel and the dial was amber color, water heater and water pump on) and only get cold water. The propane works (able to get heat via propane). When I turn on the hot water knob then the Truma dial flashes 3 times fast.
Any thoughts
terrapin is offline   Reply With Quote
Old 05-10-2021, 08:29 PM   #2
Did you remember to switch the bypass switches back to normal mode?
To test, turn off water and slowly open the yellow filter on the heater. You should see lots of water come out.
NearDenver is offline   Reply With Quote
Old 05-10-2021, 08:29 PM   #3
llamb's Avatar
Nothing offhand, but manuals are here:
Truma Support
Larry
2021 Riverstone Legacy 42FSKG
2016 RAM 3500 DRW
llamb is online now   Reply With Quote
Old 05-12-2021, 06:58 PM   #4
So I guess the little tank is empty. When pull yellow filter down nothing. I had the knob on fill tank then move d to dry camping. The knob for : winterize/sanitize...dry camping.... city water....and fill tank
Is there a specific way to fill that little tank?
Old 05-12-2021, 07:37 PM   #5
llamb's Avatar
The little tank on the Comfort/Comfort Plus is just a recirculation tank. So it will keep a small amount of water at temperature so you have a little quicker time to hot water. The comfort plus is a full recirculating system as I understand it.
Larry
2016 RAM 3500 DRW
Old 05-12-2021, 08:06 PM   #6
You need to take the kitchen drawer out so you can see the bypass switches that are behind the water heater.
Old 05-13-2021, 05:56 PM   #7
Bypass is on
As above your probably bypassing the truma. Check the valves behind drawer, should be two.
petrx is offline   Reply With Quote
Old 05-14-2021, 10:20 AM   #8
Vince and Charlette's Avatar
First, release tank pressure by opening the pressure relief valve at the top of the heater. Opening the yellow filter access could provide you with a big surprise.
2018 Berkshire 38A
Vince and Charlette is offline   Reply With Quote
Old 05-14-2021, 11:38 AM   #9
Delco Bobby's Avatar
Are you talking about the yellow lever at the top of the tank? If so when it is vertical the tank will drain. When the yellow lever is down / horizontal the tank will fill. It should stay horizontal for normal operation.
2017 Dynamax REV 24RB
2018 Ford F-150
Delco Bobby is offline   Reply With Quote
hot water, tank, tankless, water
