06-04-2021, 08:38 PM
TT wasn't winterized
Ok, travel trailer didn't get winterized. What can I expect and would it be better to have a dealer do the work?
Thanks!
06-04-2021, 09:03 PM
worst case busted water lines and traps possible water heater busted.
How much do you like plumbing
2016 wildwood x-lite 241qbxl
being jurked down the road by the beast 2007 Dodge ram 2500
5.9 cummins g56 Trans southbend clutch and a smarty
06-04-2021, 09:17 PM
Depends on if there was any water left in the lines. No water (like it was brand new), no problem.
Low point drains opened before being stored, maybe OK. minimal water had space to expand to and you may have escaped with no damage.
If the plumbing was full & depending on how deep your freezing weather gets, you may have some issues. Pex tubing is pretty resilient and can withstand some freezing so, you won't know for sure until you pressurize the system. You could pressurize the system with air first and see if there is any loss of air first.
2014 Prime Time Sanibel 3250
06-05-2021, 08:38 AM
Completely agree with Pex being pretty resilent, I’d be most concerned with its fittings, water heater and faucets.
06-05-2021, 10:22 AM
Kasual Kamper
Why not hook up the water while the rig is at your home and find out? Who knows? You might have lucked out. Or at least you'll know what needs to be addressed before your next trip.
Current: 2013 Flagstaff MicroLite 21DS
Past: 2000 Fleetwood Mallard 19N
TV: 2013 Nissan Pathfinder SL 4x4
06-05-2021, 10:36 AM
Better yet, hook up an air compressor set to 50 psi and charge the plumbing. You will find out fast if there are any "leaks", and you won't have a mess to clean up.
2016 Salem 27RKSS
06-05-2021, 10:38 AM
X2 Test with air first.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
06-05-2021, 10:40 AM
Trailer Park Supervisor
Yes, I'd start with an air charge first. Once you KNOW you have a leak, then maybe water to help you find it.
The most susceptible things to break are the water filter housing if you have one, the water pump strainer cup, the toilet flush pedal. Oh, and outside shower fixtures if you have one.
Yes, I drink the water!
06-07-2021, 06:55 PM
Water filter housing breaking was my reminder I cut it to close on garage temps this winter.
Fred W
06-07-2021, 07:23 PM
Posts #-6-7-8 are your best advise
2019 F150 4X4 7050 GVWR 1903 payload
2018 Avenger 21RBS 7700 GVWR
