Old 11-22-2020, 02:08 PM   #1
Valve confusion on Palomino Solaire
I'm not sure if I need to turn all three of these valves to Winterize? My Class A was super obvious, but this is our new 2021 FR Solaire??
ID:	243469   Click image for larger version
Marji is offline   Reply With Quote
Old 11-22-2020, 07:15 PM   #2
Simply yes.
The two on the back of the water heater are the bypass valves. Both should be positioned 90 degrees from where they currently are.
In your second picture that is the antifreeze valve, it switches the pump from the fresh water tank to the antifreeze pick up hose. That should also be turned 90 degrees so that you can pull in the antifreeze from the bottle with the attached hose.
2021 Newmar Baystar 3401
2019 Jeep Cherokee Trailhawk toad
2017.5 Forester 3051S Traded 7/2020
Steve-W is offline   Reply With Quote
Old 11-23-2020, 03:00 PM   #3
Always Learning
See if this helps:
Checkout my site for RVing tips, tricks, and info | Was a Fulltime Family for 5 years, now we're settlin' down for a spell
