Even if you found a video of this repair on an identical unit as yours, it may be plumbed differently.
If the washer is in the nose of the fifth wheel, you may be able to see some of the washer plumbing in the basement compartments.
You just have to remove the bottom cloroplast and see what you have going on. No other way to do it.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
