04-05-2017, 08:58 AM
wastegate
I'm thinking of putting a waste gate valve on the end of my sewer pipe. Seems like now, I get a little seepage when I take the cap off to hook the hose up. I've seen, and bought a twist-on style, but have not travelled with it, (twisted on, not sure if I want to) plus is sticks out a little further then stock.
So I thought about cutting off the reducer, the one with the tabs, that hold the hose/cap on, and gluing on a new coupler or reducer to be able tp glue on the gate valve, gate valve is 3" ID. I measure the OD of the pipe that I want to glue the coupler on, and got 3.5's I can't seem to find a 3.5", see 4", or 3". Has anyone did a similar thing that I want to do? Thanks
If someone has, maybe guild me to where you got the parts.
2008 Dodge 3500 Dually, Cummins. Amsoil Bypass Oil Filter, 36 Gal aux fuel tank. Mag Hytec Trans pan. Mag Hytec Diff Pan. 6 speed autostick. 3:73, Timbrens, Smarty JR. Equipped.
2016 Cedar Creek 38FB2, Hydra Star disc brakes,
400 watt Rich solar on top,200 watts of suitcase
04-05-2017, 09:15 AM
I added mine right on the end. It does stick out but not much. I did need to strengthen the support due to the added weight.
Tom & Renée
Durham, NC
2021 Jayco Class C model 27U
04-05-2017, 09:26 AM
Did you glue it, or is it a twist on?
04-05-2017, 12:47 PM
I use a twist on, but I put a hose clamp around the ears to ensure it doesn't twist off during travel. It doesn't stick out enough to be a concern.
If you're really intent on gluing one on, you could buy a glue on valve and then buy a twist on adapter and glue into the outside cuff.
Gotta go campin!
04-09-2017, 08:36 PM
I got the parts I needed at CW, glued the fittings and wastegate on
tried to post a pic, said invalid file
04-10-2017, 09:26 AM
04-10-2017, 09:28 AM
Originally Posted by wls
Here's a pic
