I have a 2017 forest river Wolfpack. When I connect to city water, I have water inside camper and then I don’t. Weird thing is it usually stops working when we flush the toilet? Is there a valve that I could check. Thank you
Does it come back after completing toilet flush? That is quite odd. New problem?
Gerry & Tammy
USN Retired
2022 XLR 335LRLE
2020 Chevy 2500HD 4x4 Gasser
and a couple of those Harley things
sold: 2021 Graywolf 22RR
If your are using one of the cheap pressure reducing valves that they sell at RV stores on your hose, this could be the problem. If you are using one, take it off and try again.
Bruce
It does not I have to go outside and turn water off and play with it for a little while sometimes it turns on with very little pressure. I think it might be valve behind the screen?
Bruce
that is what I would check first.
2021 2205S Rockwood Minilite
2019 F 150 Lariat 3.5 Eco Fx4 Max Tow
Equal-i-zer WDH, 1809 lb payload
