Old 06-29-2022, 03:22 PM   #1
Water drainIng from pump
2015 Sunseeker. About to take a trip and put 1/3 of a tank in fresh water. Ran the toilet a little and shut pump off. Went outside and water was draining out the tube connected to the pump that I use to put antifreeze in.
Anyone know what the problem might be? I’ve seen the problem with being hooked to city water and the fresh water tank filling up and it’s the relief valve on the pump, but never heard of this. Any help appreciated.
carol108 is offline   Reply With Quote
Old 07-03-2022, 12:58 AM   #2
There should be a valve in the antifreeze line. That needs to be off (handle 90 degrees to the antifreeze suction line).
NavyLCDR is online now   Reply With Quote
Old 07-03-2022, 04:04 PM   #3
New here, old elsewhere
lwbfl's Avatar
Valve isn't completely closed or has failed.
2021 Coachmen Apex Ultra Lite 253RLS
2016 Silverado 1500 Crew Cab Z71 / 6spd / 3.73
lwbfl is offline   Reply With Quote
drain, pump, water
