Old 10-21-2020, 01:24 PM   #1
Water Filter
In 2019 we bought a used 2012 Rockwood Mini Lite 1809S, I bought a case of water filters for the trailer. Several years later we traded it in for a new Mini Lite. When I eventually went to replace the water filter I found the housing took a different filter (KW1), I put the case of filters on a shelf in the basement and forgot about them. I removed the in trailer water filter canister in our current trailer and have been using the Camco 40045 canister filter externally.
I now find myself wondering if I should buy a filter housing and use these filters connected to a real pressure regulator rather than the cheap flow reducer, I would still use this external to the trailer. My problem is I canít find any information about these filters, there is no product ID on them and I haven't been able to find out any information on line. The filters are 10Ēx 2.5Ē and the end openings are 1Ē, can anyone out there supply any information and secondly should I just forget this whole endeavor?
Thanks in advance,
Dave
wmdave17 is offline   Reply With Quote
Old 10-21-2020, 01:50 PM   #2
Cabinfever97's Avatar
You may find what you are looking for here. https://www.rvwaterfilterstore.com/r...SAAEgLS8fD_BwE
Those Camco filters are better than nothing. However the micron size is HUGE, compared to a better filter.
Just noticed they are closed at the moment for maintenance.
2019 Hemisphere 272RL
2015 Ford F250 6.2L
Hensley Hitch
Cabinfever97 is offline   Reply With Quote
Old 10-24-2020, 09:40 AM   #3
Your filters are standard 10" whole house filters.
https://www.amazon.com/EcoPure-EPW2-.../dp/B00BA1DWOY
NavyLCDR is offline   Reply With Quote
water, water filter
