Old 10-21-2020, 01:24 PM   #1
Water Filter
In 2019 we bought a used 2012 Rockwood Mini Lite 1809S, I bought a case of water filters for the trailer. Several years later we traded it in for a new Mini Lite. When I eventually went to replace the water filter I found the housing took a different filter (KW1), I put the case of filters on a shelf in the basement and forgot about them. I removed the in trailer water filter canister in our current trailer and have been using the Camco 40045 canister filter externally.
I now find myself wondering if I should buy a filter housing and use these filters connected to a real pressure regulator rather than the cheap flow reducer, I would still use this external to the trailer. My problem is I can’t find any information about these filters, there is no product ID on them and I haven't been able to find out any information on line. The filters are 10”x 2.5” and the end openings are 1”, can anyone out there supply any information and secondly should I just forget this whole endeavor?
Thanks in advance,
Dave
wmdave17 is offline   Reply With Quote
Old 10-21-2020, 01:50 PM   #2
Cabinfever97's Avatar
You may find what you are looking for here. https://www.rvwaterfilterstore.com/r...SAAEgLS8fD_BwE
Those Camco filters are better than nothing. However the micron size is HUGE, compared to a better filter.
Just noticed they are closed at the moment for maintenance.
2019 Hemisphere 272RL
2015 Ford F250 6.2L
2005 Jayco Bantam Flier
Hensley Hitch
Cabinfever97 is offline   Reply With Quote
Old 10-24-2020, 09:40 AM   #3
Your filters are standard 10" whole house filters.
https://www.amazon.com/EcoPure-EPW2-.../dp/B00BA1DWOY
NavyLCDR is offline   Reply With Quote
water, water filter
