Old 12-15-2020, 07:59 AM   #1
Water Filter
When using water from the fresh water tank does it go through the water filter?
John
geegoat is offline   Reply With Quote
Old 12-15-2020, 09:44 AM   #2
bubbles's Avatar
Your GT 378 has a whole house filter and the holding tank water via the pump does pass through the filter. Filling the holding tank requires an external filter if filtering is desired.
Old 12-15-2020, 09:50 AM   #3
Just as confused as you
Scrapper's Avatar
Yes, the water pump is installed between the tank and the filter usually in such a way you have fresh water tank > antifreeze input > water pump > city water > filter > plumbing system.
Name:	Bypass Valves.jpg
Richard & Jill
Camping since 1989
I deserve hazard pay when camping with my relatives.
water, water filter
