02-22-2013, 02:36 PM
Water Filter
New to the TT lifestyle, the TT I bought is a 2013 Wildwood X-Lite does not come with a whole camper water filter so I was wondering if the faucets allow for a PUR water filter to be attached to the kitchen sink. I don't want to filter all the water. Any help will be great. Tanks in advance
02-22-2013, 03:13 PM
Originally Posted by TeresaInCAL
I don't have continues water flow at my campground (wish i did) that's why I was asking. Thanks
02-22-2013, 03:45 PM
Denver, CO
Faucets are kinda light duty, so I would do an separate spigot with a cartridge filter. I have an Omnipure from rvwaterfilterstore.com and it's great.
2017 Fuse 23T
You might consider a reverse osmosis setup. Take a look at what's on ebay. The ones for an RV are quite small and don't have waste water used up in the process that would have to be drained away. They are in the range of $100 - 200.
I installed a couple of inline 5" filters near the kitchen sink for the cold water only - one is a carbon filter and the other is a sediment filter. The flow rate is pretty slow with 2 filters in line though. But DW refuses to drink the filtered water and will only drink store bought bottled water. I don't have any trouble drinking the filtered water.
I don't think you would want to filter the entire water supply as you'd need a large filter like a 10" cartridge to get a decent flow rate and quality filtration. A 1/2" garden hose typically provides about 5 gpm to give you an idea of the flow rate into an RV. I know that you can get the inline ones that go on the outside incoming supply connection but I have my doubts on the quality of the filtration on such small size filters and don't know what the flow rate is. You don't really need to filter water for the toilet and shower unless maybe the water source is not very goo.
Gil & Deb & Dougal the Springer Spaniel
Langley, BC
02-22-2013, 03:54 PM
TeresaInCAL
Right, but you can filter the water as you're filling the tank.
We do this, and also have a countertop PUR filter, to extra filter drinking/coffee water.
Teresa
2013 f150 Ecoboost 4x4
2009 Gray Wolf, 22BH
02-22-2013, 03:59 PM
2020 Flagstaff Micro Lite 22FBS
02-22-2013, 04:12 PM
In Ontario the water quality varies a lot and sometimes there is so much chlorine that it is not drinkable. I would prefer not to put that water in my fresh water tank so I have a large whole house filter canister and I use a carbon filter that filters to 2 micron.
The system flow is fast enough so I don't have a lineup behind me and the water is fine to drink with almost no chlorine smell. I put a reducer from 1" fittings to the filter housing to 1/2 inch and a garden hose adapter for the fresh water hose.
DuPont Heavy Duty Whole House Water Filtration System-WFHD13001B at The Home Depot
Heavy Duty Carbon Pleated Cartridge-WFHDC8001 at The Home Depot
Apologies about the links, I couldn't figure out how to embed pictures.
regards,
Extremebike
2004 Ford F550 6l Lariat SuperCrew, Fontaine Bed,
Link Systems Air Ride
2011 Sterling 32RL with Michelin XPS tires
02-22-2013, 04:29 PM
extremebike - good choice. Is that a 5" or 10" filter? The filter cost at HD seems awfully high. I bought our 5" ones at Water Filters: Replacement Water Filter Cartridges for Culligan, Everpure, Samsung, Pur, Brita, Pentek, GE, and more for just over $10 each. You should be able to buy them at wholesale plumbing places for a good price too.
We use a 10" carbon filter cartridge on our house due to the well water and it has a pretty good flow rate.
Water Filters: Replacement Water Filter Cartridges for Culligan, Everpure, Samsung, Pur, Brita, Pentek, GE, and more has a lot of good info on which filters to choose.
Langley, BC
03-07-2013, 10:55 AM
When we go camping we freeze 2 cases of bottled water. The bottles sometimes expand but don't break. We put them in the coolers along with other items we want to keep cold. This way we don't take up cooler room with ice.
I have been considering trying a large bottle water item like.
Avanti Products Thermoelectric Cold Water Cooler / Dispenser: Appliances : Walmart.com
Since it is electronic I could put it outside next to the camper and have easy access to it at any time.
22 Forest River RPod 192
2019 Nissan Titan
03-07-2013, 11:05 AM
Denver, CO
Remember that chlorine is a GOOD thing, as it kills bad bugs that can make you sick AND if you remove it all before the water goes into your tank and the tank sits for awhile, you can create your own bad water. I think it is best for the tanks water to be filtered for sediment but not chlorine, and then filtered at. The spigot.
3ppm residual chlorine is a good point to have in you your tank and plumbing.
AND sanitize your entire system at least annually with 50-100 ppm chlorine.
Chlorine is, after all natural. LOL
There is lots of hysteria out there about " chemical" and while some of it is good, people can go overboard about it..
IMPO
2017 Fuse 23T
03-07-2013, 11:45 AM
Above is true,I know your unit is New but change out the kitchen faucet for a better Home metal type that you can screw a Omnipure on the outlet pipe. You will be on here asking about the squeeking,plastic faucet if you dont change it anyway.  I changed all of my faucets before the first trip,went to Menards they have a good selection.  Youroo!!
03-07-2013, 07:26 PM
It's the 10 inch large canister and filter. I figured out that someone would shoot me waiting for the FW to fill. The large filter flows through about as fast as the tap will provide. The carbon filter has a much small screen so you need the large one to maintain the flow.
regards,
Extremebike
04-16-2013, 07:35 AM
That camco filter you use is a 100 micron filter which DOES NOT filter much just an fyi.
04-16-2013, 07:50 AM
We have a Pur 10" on the outside for shore water.. 5 micron 2.5 gpm. it lasts about 3 mo. fresh water tank gets cleaned, then we filter that before our trip... only put about 10 or 15 gals for travel...
04-16-2013, 10:54 PM
TeresaInCAL
Thanks.
We don't drink this water, this is just household, mostly. I sometimes will use it through the PURE water filter, then in the coffee maker.
Teresa
