Old 04-03-2013, 03:40 PM   #1
Mike G's Avatar
Water Filter
We just got back from W.Md. on our first trip of the year, everything worked fine and there were no issues with the camper.
I forgot to buy a new water filter for the camper(A122) from the local Camping World store, so I went to WalMart and purchased a Camco (blue) RV filter that hooks up to the fresh water hose. I left the interior filter housing empty of a filter and just used the Camco one. The water pressure was much better and I think I will just go this route from now on, it`s a lot easier to replace and less chance of a leak inside.
________________________
2012 A122 (SOLD)
2016 A122 SXR (New)
2016 Toyota Tacoma DCLB
Mike G is offline   Reply With Quote
Old 04-03-2013, 08:38 PM   #2
That's exactly what we do on our Sabre. You are using a water pressure regulator aren't you?
Old 04-03-2013, 08:48 PM   #3
Always Learning
This post made me realize that I never re-installed a water filter at all for this trip!
Worst water pressure we've dealt with. I almost wonder if my Watts regulator got bumped/jostled to lower its pressure. My guess it's the park and it just has low water pressure.
Old 04-03-2013, 09:17 PM   #4
Mike G's Avatar
Yup, I have used one on all of my campers. Replacing water lines on a camper is not fun.
2012 A122 (SOLD)
2016 A122 SXR (New)
Old 04-03-2013, 09:29 PM   #5
Amen to that!
Old 04-03-2013, 09:44 PM   #6
Engineer of Crazy Train
ChooChooMan74's Avatar
I noticed a drip from my filter today. I need to go and get a few O-rings from my friendly FR dealer.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183 (SOLD due to 2 years off work)
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 04-04-2013, 12:22 PM   #7
IndyRC's Avatar
We removed our interior filter as well because of poor water pressure.
IndyRC is offline   Reply With Quote
Old 04-05-2013, 02:51 PM   #8
I am trying to become a first time A-Frame owner this week. So I am looking for all the little things a newbee needs to know. Where is the interior water filter on these models?
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 04-05-2013, 03:13 PM   #9
TURBS's Avatar
If it has one it will be right near the water pump.
Turbs
Old 04-05-2013, 03:25 PM   #10
Thanks.
Tom
2012 Rockwood A122S
Old 04-05-2013, 03:43 PM   #11
Speaking about water filters, do you notice FR mounts them low when there could be several inches more room above. Then, when you remove it, you have to tip it? I think i may mod that now!
Edit. 10 mins later, better than new. The bottom holes were in luan and the top ones were in solid wood. Moved the holes up and now the top screws are also in solid wood. And I can remove the filter without tipping.
Locomotive Engineer
Old 04-05-2013, 04:32 PM   #12
Mostly Harmless
thehamguy1's Avatar
Under the sink, right hand side, above the shelf and far enough back in that you'll have to get down to the door level to see it.
It's never too late to have a happy childhood!
Lee, WU0V, and Courtenay, N0ZDT
2011 Rockwood A128
2000 Silverado 1500 pickup
60W solar system
2000W inverter generator
thehamguy1 is offline   Reply With Quote
Old 04-05-2013, 07:55 PM   #13
Jeep4Two's Avatar
You only need the location once, to remove it... It restricts the water flow horribly. Either no filter, or an inline on the supply hose is what most of us do.
Jeep4Two
2011 FR Rockwood Premiere A126 Hard Side
TV=2011 Jeep Wrangler Sahara 2 Dr
Reese 66065 WDH, Curt WDH Shank #17120
Prodigy P2 Brake Controller, Mopar 7-pin Harness
B&M Transmission Cooler (#70268)
Jeep4Two is offline   Reply With Quote
Old 04-05-2013, 08:02 PM   #14
I find it restricts it no more than the pressure in my house. Maybe I am just use to horrible pressure. To me, having a quality filter is well worth it.
Locomotive Engineer
Old 04-05-2013, 09:42 PM   #15
Jeep4Two's Avatar
I'm sure each persons experience will vary. Maybe I had a bad filter. With it, water flow on my A126 was so low that filling a coffee pot (8 cup model, so pretty small) took more than a minute. Without, I can fill in less than half the time.
I just don't use one at all and bri g drinking water along, and only use tank or CG water for non consumption uses.
Maybe one day ill get a new filter cartridge and give it another shot.
Jeep4Two
Old 04-06-2013, 03:09 PM   #16
DGrissom's Avatar
I am in the process of getting ready to remove our internal filter. I think we'll gain a small amount of space as well as improved pressure. I am going to camping world today to look at external filters.
We've always used ours for safety sake as we don't always trust the water at the campsites.
I wish we could filter just the onboard tank with it. Although I sanitize the system regularly, I like the thought of the extra protection.
David and Jo Ann G. (& Kenzie the Sheltie)
Prattville, Alabama
2018 Flagstaff E-Pro 19FD "Phoebe"
DGrissom is offline   Reply With Quote
Old 04-06-2013, 03:49 PM   #17
When using the water filter I had almost no water pressure at all. Removed the filter and had good water pressure. I removed the filter housing and put in a coupling to connect the two lines. We only use the water from the tank for dishes and such. We bring our own drinking water from home or in bottles.
2021 Apex Nano 191RBS OFF GRID
2017 Chevy Colorado Z71 4x4 3.6 L
backpacker3 is offline   Reply With Quote
Old 04-08-2013, 03:25 PM   #18
I have never used the filter inside my filter container ...
i would like to put a bypass in .. to be able to screw on to the coupling .. and negate having that water in the cabin of the trailer ... and also the antifreeze that im about to push out in the next few days ..
if anyone has a mod/flee bay purchase ... that does this i would certainly be interested....im basically looking for disk shaped thingy .. that would take the place of the filter holder ....
d-mo
2008 Nissan Frontier 4x4
2011 Rockwood A122
D-mo is offline   Reply With Quote
Old 04-08-2013, 03:37 PM   #19
Herk7769's Avatar
Sometimes it goes without saying, but pressure preset regulators only reduce incoming pressure and do not increase it. Been to many campgrounds with low (and sometimes very low) water pressure.
If the pressure is really bad, I just use it to fill my freshwater tank and run my pump. This has happened at more than one campground.
Another thing I do is fill my fresh tank when we will be camping for a while (even with hookups). This precaution paid off in spades at MacDill AFB in Tampa, FL recently when the City of Tampa Water Works had a polluted water problem. They blew the siren on base and used the "Giant Voice" system to alert everyone that the water was compromised and to boil all the water coming out of the spigots. We just shut ours off and used the on board water until the emergency had passed.
We use it up a few days before we depart.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 04-08-2013, 03:39 PM   #20
Herk7769's Avatar
d-mo
I removed our filter and installed a 2 gallon pressure tank. LOVE the mod.
Name:	6 June 2009 025.jpg
ID:	27430   Click image for larger version
ID:	27431   Click image for larger version
