If there are no lugs on the canister for a wrench to grip it's most likely a "Push UP and Twist" type canister.
Make sure there is ZERO pressure in the water system and then push canister up into the mounting bracket then twist to unlock, Pull down to remove canister.
The "Pointer" on the edge of the mounting bracket is then aligned with the arrow that's (should be) on the canister when re-assembling.
