Water Filter location
I cannot for my life find anything which tells me where to find the water filter on my 2019 T263BHXL - Salem Cruise Lite. I have looked under the sink, under the back bunk (where the water heater is), under the tub, under the closet, under the sink in the bathroom, inside the access panel under that sink...well you get the point. The city water connection is further back than I can get to under the bunk and there is no access door or anything close near that connection.
I have opened pretty much all the inside access panels I can find. Does this model not come wth one? If so, where should I check next?
Thanks for your patience. I have tried searching but the only results I came up with either showed some kind of inline application which is mounted on a wall somewhere or deals with other models. Those are the spaces above which I have already checked out.
Doug
