Originally Posted by joesaintp
I don’t know where valve #3 goes but I do have an exterior connection opening on the exterior wall labeled “antifreeze feed” or something like that. If this is the case then it should be shut and both #1 and #2 should point perpendicular to their lines and towards the water heater tank to operate then correct?
Correct. Valve #3 will be the selector on the inlet side of the water pump. In one position will will suck water in from the fresh water tank. In the other position it will suck in whatever is connected to the antifreeze feed connection. Valves 1 and 2 should point towards the water heater. Then fill your fw tank at least 1/3 full, install at least the bowl onto the water filter housing, and turn on the water pump. Open a hot water faucet. In a few minutes it should fill the water filter, then the water heater, then water should start coming out the hot water faucet.
If after a few minutes, if the pump sounds like it is running with no load, and you still have no water, then likely valve #3 is in the wrong position and you are sucking air in through the antifreeze connection. The pump will not be damaged by sucking air for a few minutes, no worries there.
