12-01-2020, 09:13 PM
Water Heater Anode Rod deteriorating
Hi all,
I have a 2021 forest river fsx Salem 179dbx bought in March this year. I went to winterize it today and when taking the water heater anode plug out of the hot water tank to drain it and it looked degraded - like it had calcium build up - I took a photo and posted below. Anyone heard of it before or what might cause it other than maybe just hard water ? Can I just replace it with a new one or is there potentially an underlying issue to sort out as well?
Thanks in advance for any help !
12-01-2020, 09:17 PM
Welcome to the forum from New Jersey, Depending on the water quality those rods are designed to give up,You can just replace it next season. Some drain the water heater between trips.
12-01-2020, 09:18 PM
Thank you!
12-01-2020, 09:20 PM
That's what it's intended to do. Looks to me like you have a few more years of use in the that one.
Apply some teflon tape to the threads on the new rod.
12-01-2020, 09:51 PM
But don’t even install a new anode while this one is still good.
12-01-2020, 10:01 PM
They are supposed to degrade.
2016 RAM 2500 Cummins SLT Lone Star 4X4 LB
2016 Windjammer 3029W Platinum
I'm not an expert. But I play one on the internet.
You live & learn or you don't live long.
If you don't punish your children, life will.
12-01-2020, 10:17 PM
This^
We're on our 5th season with ours and it still has life left in it
12-01-2020, 10:21 PM
Thanks all - super helpful. Am new to rv’s ... so much to learn !
12-02-2020, 12:07 AM
a suggestion. Using the above attached image I'd replace when the rod reaches 75%. The smaller in diameter the anode rod is the faster it will be consumed. That last little bit can go quick and when it's down to just the center rod electrolysis/corrosion will start in on the inside of your tank.
12-02-2020, 12:20 AM
That's what we are here for, to share experiences and wisdom.
This thread may help and is aimed at new RV owners.
https://www.forestriverforums.com/fo...ts-157524.html
Included in that link above is a reference to our Five(5) different Suburban video guides, one of which explains the anode rod function and replacement.
Here is a direct link to just that video:
Water Heater Series 01: Video 01 - Suburban Anode Rod
2011 Flagstaff 831 RLBSS
12-02-2020, 12:35 AM
Just as confused as you
Though on-demand water heaters don't have anode rods, it's the same with your water heater in your home has an anode rod which needs to be inspected.
Richard & Jill
12-02-2020, 02:57 PM
The picture you posted looks absolutely normal. It's doing it's job. You've still got plenty of life left on it.
12-02-2020, 03:38 PM
X2. I noticed in the OP's pic that deterioration is more pronounced near the threads, almost down to the "wire". It is certainly doing it's job. What you don't want to happen is the rod breaking off and falling into the tank. You'll play hell trying to get it out if that happens.
2016 Salem 27RKSS
12-02-2020, 03:44 PM
Have you ever had that to happen? Mine always wears more at the threads, some times to the point l have been concerned with it, l change mine probably sooner than l shoud, especially when it wears at the threads.
12-02-2020, 04:19 PM
AKA: 'tiredTeacher
On a side note. I bought a pair of 18" tweezers. I can't count the times they've saved my butt.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
12-02-2020, 04:31 PM
No worries
No worries about that. The sacrificial part is aluminum or magnesium. The wire down the center is steel and decomposes very slowly, if at all.
A few shards of aluminum or magnesium in the bottom of the heater are not harmful. If it's a concern, just insert the hose nozzle into the anode opening and flush them out while the water heater is bypassed.
Larry
12-02-2020, 04:54 PM
The anode is sacrificial and intended to be replaced. They are inexpensive and readily available on Amazon. My dealer stocks them as well. Kind of a pain to install, however, only because it has a tapered thread with a short lead and the cantilevered weight of the anode rod makes it a little difficult to get started without cross threading. I pull mine every winter to drain the tank when winterizing and I always carry a spare.
12-02-2020, 04:57 PM
Also, if you pull yours to drain at winterizing it's a good idea to rinse out the tank after it drains because those corrosion deposits fall off an lay in the bottom of the tank.
12-02-2020, 04:59 PM
... as stated on post #17.
