Old 05-15-2017, 08:15 AM   #1
Water Heater doesn't attempt to light on LP
Hello All!
I just purchased a used 2012 Surveyor Sport this past week. We went out for our first trip and found an issue with the Water Heater...I was hoping someone could help me troubleshoot.
I am having issues with my Suburban Water Heater SW6DE. The Electric switch on the outside tank heats properly, but we can't get the LP side to work. The On/Off switch inside my camper doesn't light up when switched to on-my understanding is it should when first turning on until the unit lights. No Attempt to ignite-No Clicking noise at all, no smell of Gas. Gas is working fine on the stove.
Do you have any advice on how to start troubleshooting?
hollyasc is offline   Reply With Quote
Old 05-15-2017, 08:19 AM   #2
Flybob's Avatar
There is a safety lock out that prevents it from trying to light if it has failed several times. This can occur if someone turned it on when there was no propane. To reset, pull the fuse for the 12V control power to the WH and wait 10 sec and reinstall. if you haven't used propane side of it before, run the stove for a few minutes to insure the air in the propane line is bled out.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-15-2017, 08:21 AM   #3
Thanks I will give it a shot.
Edited to say that didn't resolve the issue. Thanks!
Old 05-15-2017, 04:01 PM   #4
Head Rambler
Did you test the fuse to ensure that it was good when you pulled it? Sometimes they don't 'look' blown when they actually are.
Is the water in the heater hot when trying to fire the heater on gas? If it's hot enough, that will keep the gas side from firing.
Have you checked the Hi-Limit/Eco switch and thermostat to see if it's passing power? There's one for both the AC and DC side. It's under a cover in the heater compartment near the burner assembly.
Here's a troubleshooting guide if you don't already have one.
Gotta go campin!
Old 05-15-2017, 04:04 PM   #5
fonzie's Avatar
I would shut the electric off, turn on gas switch and use your hot water, if all is good it should fire up after a while....it will not turn on if water is already hot from electric side....
Fonzie
Nights Camped:2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42) 2019(28)
Old 05-19-2017, 09:44 PM   #6
Thank you all. We were able to narrow it down to the hi limit/thermostat. Replaced that and all is right with the world. ��
Old 05-19-2017, 10:14 PM   #7
Herk7769's Avatar
Replaced or reset?
There is a reset button under the rubber covers. The rubber covers prevent corrosion and shocks from the AC thermostat (on the left; DC on the right).
Note the melted wire on the left AC thermostat in the photo.
Name:	waterheater reset buttons.jpg
ID:	138469   Click image for larger version
Name:	bad connection.jpg
ID:	138470   Click image for larger version
Name:	thermostat from manual.jpg
ID:	138471   Click image for larger version
Name:	Limit Switch Reset.jpg
HAM CALLSIGN - KC3FFW
Old 05-19-2017, 10:18 PM   #8
Replaced. We couldn't get it to reset.
Old 05-20-2017, 12:19 AM   #9
Herk7769's Avatar
OK. If it happens again, here is the place to buy a replacement:
Suburban RV Water Heater 12 Volt Thermostat 232282 | eBay
The other side is about the same price.
https://accessories.lazydays.com/sub...FduNswodg8YBng
There is only one nut/ lock washer and the two terminal spades.
heater, light, water, water heater
