Originally Posted by rjw54
Any idea where relay might be?
Well, I believe on the Suburban SW_DEL models, the relay is built into the control board. You would have to look at the wiring going to water heater. If it is a Suburban SW_DEL model, there should be two 12 volt positive wires. In the junction box for the water heater, the 12 volt wire controlling LP gas function is connected to the red wire. The 12 volt wire controlling the electric heating element relay is connected to the orange wire. The black wire in the junction box goes to the DSL indicator light on the control panel.
If you have a 12 volt DC wire connected to an orange wire in junction box at the water heater, you would have to check that voltage switches on and off there. The ground in the junction box is the green wire.
If you have a SW_DE model Suburban Water Heater it has an electric element that is only switched on/off with a switch on the front of the water heater and has no relay nor inside switch. It will not have the orange wire in the junction box.
