Originally Posted by NavyLCDR
Did you remove the anode rod? If you did not remove the anode rod, then you did not properly drain the water heater.
If it's really gushing, did the OP put the anode back in before turning on the water? Maybe it's gushing out the anode port.
Or maybe he flipped up the lever on the T&P valve to vent it so it drained faster and it's gushing out the T&P valve.
TEB, can you tell us EXACTLY where the water is gushing from? Open the louvered door on the side of the trailer, run water, take a picture and post it here. It is possible that there's a fix that won't cost a penny.
If you can't reproduce the gushing with water, take a picture and mark it up to show where the water was coming from and post it here.
To post a picture, put it on your computer.
Click Reply under this post.
Type your comments.
Click the paperclip item.
In the popup, click Choose File
Navigate to where you stored the picture and select it. (Open)
Click Upload.
