Old 11-17-2020, 04:28 PM   #1
Global Nomad
Scheinin's Avatar
Water in the Gap
I just purchased a Camco heated water hose. What I did not consider is water sitting in my pressure regulator, which is between the heated campground spigot and my heated hose, as well as where the heated hose attaches to my water inlet hose.
When the water sits overnight, how do I keep these two areas from freezing?
Steven J. Scheinin
2015 RAM 3500 4X4
6.7L CTD Dually pulling a
2016 Cedar Creek 36CKTS (Center Kitchen Three Slides)
Scheinin is offline   Reply With Quote
Old 11-17-2020, 04:54 PM   #2
Most folks use a short heat tape on the regulator and/or filter, usually wrapping it up over the spigot/hydrant. You say your hydrant is already heated so maybe just some insulation and the residual heat from the heated hydrant and the hose will suffice.
You can also get something like this for the city water connection on the side of your R/V. How well it works depends on how close to the end of your heated water hose, is actually heated.
Days Camped: '18=51 '19=58 '20=110 '21=21
water
