The backflow preventer is stuck open somewhat and allowing the city water to back fill the fresh water tank. Try shutting off the city water and turn on the pump and running some water thru a faucet. This may reset the backflow preventer flapper type valve. If this does not work the first time try again, after the second or third try you may have to replace the back flow preventer.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
