Old 05-14-2017, 12:26 PM   #1
Water leaking from mystery drain line
Does anyone know what this drain line is for? It is on the left side of the camper next to the fresh water drain tube. 2017 Vibe
ID:	137820Click image for larger version
benkeller84 is offline   Reply With Quote
Old 05-14-2017, 12:37 PM   #2
It would be the vent/overflow line for your freshwater tank.
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
retiredcamper47 is offline   Reply With Quote
Old 05-14-2017, 02:44 PM   #3
Bob
Thanks!
Old 05-24-2017, 11:10 AM   #4
most likely he is right. It could also be a drain from the fridge for condensed water, but those usually go out the vent on the fridge.
Anyone know why Forest River was too lazy to connect the fresh water vent lines to the water fill port (with a built in vent with a screen) like other manufacturers?
Its very annoying that they took the lazy route... if you try to travel with fresh water you will need to add a cap to that vent line or most of the water will slosh out while driving.
mkosu04 is offline   Reply With Quote
drain, leak, water, water leak
