Old 02-07-2017, 04:52 PM   #1
Water leaks from City connection
Hey all -
Noticed a strange issue last time I took my 2011 Mini-lite 1809s out last weekend boondocking and noticed water coming out of the city water connection. Actually the leak was not from the actual fill but from behind it where is seals up against the trailer.
Any clue how this can happen or whats going on?
Thanks in advance.
Goalieken is offline   Reply With Quote
Old 02-07-2017, 05:55 PM   #2
Iwannacamp's Avatar
may be the GH connection. Stack two gaskets or get an o-ring type gasket... they are taller/thicker. Cheap try. Mine did it too.
2017 Puma 297RLSS
Old 02-07-2017, 06:08 PM   #3
crunchman12001's Avatar
Check the space on the interior where the water connection comes into the trailer to make sure it is not leaking inside.
2015 F-250 FX4
Old 02-08-2017, 10:09 AM   #4
I'll check it out this weekend and let you know what I find.
Old 02-08-2017, 10:37 AM   #5
waiter21's Avatar
Most City Water connections have a built in backflow preventer valve. Usually, during the first winter, a little water is trapped in the valve, freezes, and screws up the valve, and then water leaks.
Replace the hose gasket (the rubber gasket) and use a pair of pliers to snug up the cap thats on the connection.
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 02-08-2017, 02:46 PM   #6
Left Coast
Think there's a check valve there also, but as others have posted, bet it'll be a loose pex clamp or hose clamp
Old 02-08-2017, 02:52 PM   #7
Here is a video that will give you a better understanding what/how the plumbing connects to the back of the city water inlet.
Days Camped: '17=30 '18=51 '19=58 '20=83
Old 02-08-2017, 06:54 PM   #8
Thanks for all for the help. I am still wondering how water can leak out of the highest point especially when i am using fresh water. It must be when the pump is on in order to pressurize it?..... i find it really odd. It also seemed to be leaking there while trailering.
I'm new to travel trailers so this is a good learning experience.
Once again i'll take it apart this weekend and let you know what i find.
Thanks again!
Old 02-08-2017, 10:22 PM   #9
Left Coast
Check valve in pump not seated
Old 02-08-2017, 10:26 PM   #10
Bob, the OP is complaining of a leak at the city water connection when using the pump. Not the other way around.
Old 02-08-2017, 10:39 PM   #11
Left Coast
OK.....Then the check valve in the city water hose
Old 02-09-2017, 06:27 AM   #12
The OP says it seems to leak behind and inside at the city water connection.
Old 02-09-2017, 10:45 AM   #13
Yep - when using the fresh water tank and not connected to city water.
Old 02-09-2017, 10:49 AM   #14
city water leak
he says he is using the pump with city water ,my trailer directions says not to use the pump when using city water .If you do it will pressurize the system and cause leaks. maybe that is what is causing the leaks . I don't know if that is what is happening. I think I would try city water without the pump. If it still leaks then try new fittings and gaskets and clamps.
cdog7201 is offline   Reply With Quote
Old 02-09-2017, 06:16 PM   #15
I am not using the pump with city water. Its rarely even hooked up to city water....
Old 02-09-2017, 10:10 PM   #16
leak at city connection
Ok sorry I misunderstood now that means water is probably getting in that line from the water supply and is back feeding .Must be the back flo valve.
Old 02-09-2017, 11:14 PM   #17
Thanks again!
Here's a plumbing diagram that covers probably 95% of RVs. You'll see that the output of the water pump has a path directly to the back of the city water connection.
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 02-14-2017, 09:15 AM   #18
Well I took it all apart this weekend and it seems as if the check valve in the city water connection is bad. Ordered a new one..
Thanks for the assistance.
Old 02-14-2017, 09:21 AM   #19
Left Coast
Tada!...
Old 02-14-2017, 10:36 AM   #20
I don't know why none of us told you this (focused on the cause rather than the solution, I guess), but:
The usual fix for a leaking check valve is to put some water in the fresh water tank, turn off the city water, and run the pump for a minute or two. That usually flushes out the valve and allows it to reseat properly. If you've still got it all apart, I'd go ahead and replace the valve, but if not, you might want to try flushing it first and keep the new valve as a spare for when it really does fail.
leak, water, water leak
