Old 04-17-2017, 08:21 PM   #1
Water out the rear of h2o heater
Went to de-winterize the 2013 crusader today like I've done since 2013 and "suprise " water comes running out one of the hoses in the rear of water heater. Have 3 fans drying the floor. Almost dry. But looks like it's off to the rv repairman. Luckily for me he is a good friend and won't screw me around. Not what I was hoping for. Looks like one of the white tubes is broke. Worst design I've ever seen behind the water heater.
2013 Crusader 325RES
2006 Chevy 2500 CC/SB Duramax/Ally 4X4
rhollar is offline   Reply With Quote
Old 04-17-2017, 08:24 PM   #2
SeaDog's Avatar
You may want to ensure that what ever caused the hose to split did not damage your water heater.
Retired Navy
2016 Flagstaff 26 FKWS
Old 04-17-2017, 08:27 PM   #3
True, that's why it's going in. I can't get up in behind to see what's going on, plus my rv guy will fix what needs fixing. Frustrating since I had antifreeze running through entire system .
Old 04-17-2017, 08:59 PM   #4
Did you open the bypass valve when you winterized??
John & Susan, Olivia the dachshund
2011 Georgetown 337DS
2003 Dodge Dakota
Hampton Roads VA
2016 174 Days camping, 2017 66 days 2018 24 days 2019 48 days
mogman is offline   Reply With Quote
Old 04-17-2017, 09:01 PM   #5
I think so, pink went through everything. Did it the same way for the last 3 years.
heater, water
