Old 04-23-2017, 12:54 PM   #1
2016 Rockwood 8325SS
Water Pump
I just fill my fresh water tank and turned on the pump. My question is that the pump is running but very little water is coming out of sink. Any suggestion would be helpful. I am checking all systems before our first outing, every system is fine except very little water when using the water pump. When my unit is hooked up to a water supply no problems. Thanks for any help.
Barstorm is offline   Reply With Quote
Old 04-23-2017, 01:03 PM   #2
Left Coast
.Using regulator when hooked up to city water?
Old 04-23-2017, 01:08 PM   #3
Flybob's Avatar
It can take a few minutes to fill your hot water tank and pressurize the system. You have to add 6 Gals of water to the water tank until you can build up system pressure. Also check to make sure the winterization valve on the intake to the water pump is in the service/summer position.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-23-2017, 01:37 PM   #4
Thanks for the tips! A little tap from a hammer on the pump was all that was needed. Thanks as always for the fast replies. Here's to a great camping season.
Old 04-23-2017, 01:39 PM   #5
Left Coast
My kind of fix!......lol
Old 04-25-2017, 02:38 PM   #6
Location Of water pump and Accesability
Hi, I am new to this forum however I am hoping to get some advice if possible. I am trying to locate the water filter and pump for my Rockwood 5th Wheel 8280WS. I have heard many stories as to where it may be and the issues in getting to the pump. I live in Canada, Alberta therefore I need to ensure I can winterise my unit when the time comes. Many thanks for your help
Robshaz157 is offline   Reply With Quote
Old 04-25-2017, 02:47 PM   #7
Hey, you must be an electrician!
2011 Traverse LT, 3.6L, FWD
Old 04-25-2017, 04:01 PM   #8
Left Coast
Pump is under fridge, behind breaker/ fuse panel......
I think it's fairly easy to get to
pump, water, water pump
