Here is what often happens: when the tanks are being installed, holes are cut for the piping and debris falls into the tank and somehow finds it's way through the sand screen into the pump where it settles on the membrane. The pump starts cycling every so often, loses prime and/or keeps running for a few more seconds after the tap has been turned off. This can happen the 1st time the tank is being used or even after a couple of years and it is no reason to have the pump replaced.
If you're handy with basic tools you could take the pump out and split it (inspect the sand screen while you're at it), I bet you'll find tiny white plastic pieces stuck in there. If you're not sure take pictures every step of the way but it is actually really simple.
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
