Old 11-01-2016, 03:30 PM   #1
Big Gator's Avatar
Question Water Pump extra hose?
I had water running out from under the converter so I investigated further and found water coming from a hose that appears to not go anywhere on the water pump. I have only used the water pump once to simply flush the toliet while dumping. Turned it on, flushed the toliet then turned it off.
What is the purpose of this hose and should I of done something differently while using the water pump even for that brief usage?
2016 Shasta Oasis 18FQ
Big Gator is offline   Reply With Quote
Old 11-01-2016, 08:24 PM   #2
I believe it is used for winterizing.. you bypass the hose coming in from fresh water tank and the water pump pulls antifreeze from the jug via that 3rd hose
tuscani is offline   Reply With Quote
pump, water, water pump
